Which feature do you need the most?
Forums: Which feature do you need the most?
Volumetric: fire, smoke, clouds
368
17%
Hair&Fur
284
13%
Render Passes
237
11%
Particles
224
10%
Mixing of daylight and HDRI environment
210
9%
Multilight
155
7%
Region Render
139
6%
Rounded edges
130
6%
Multi UV channels
129
6%
Undo
103
5%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
86
4%
Network render
83
4%
Subdivision surfaces (OpenSubDiv)
80
4%
Total votes : 2228
Re: Which feature do you need the most?
Postby J.C » Fri Nov 02, 2018 8:41 pm
J.C Fri Nov 02, 2018 8:41 pm
Despot wrote:I really wish you'd add a threshold or a tightener to Bloom and Glare.
The ability to be able to focus the effect on just the brightest pixels in the image gives a much more realistic result.
+10000
System – Windows 11
J.C
Postby tim_grove » Sat Nov 03, 2018 9:14 am
tim_grove Sat Nov 03, 2018 9:14 am
+10000
Yep agree with this massively.
tim_grove
Postby Goldorak » Sun Nov 04, 2018 11:03 am
Goldorak Sun Nov 04, 2018 11:03 am
On the todo list
Goldorak
Postby VVG » Sun Nov 04, 2018 7:57 pm
VVG Sun Nov 04, 2018 7:57 pm
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG
Postby Phantom107 » Sun Nov 04, 2018 10:31 pm
Phantom107 Sun Nov 04, 2018 10:31 pm
Can we get a 'reload geometry' button on FBX nodes in Octane Standalone (v3) ? I'm now exporting FBX and it's a pain to test...
Phantom107
Postby bloomendale_1 » Wed Nov 07, 2018 7:08 am
bloomendale_1 Wed Nov 07, 2018 7:08 am
i'm new to Octane so only most important)
1) be able to pass geo data (attribs) to octane - i know that houdini is light years ahead of any software on the market in terms of passing and using data, but even there i have to use uvs to sample textures (on discs or generated on the fly in COPs) and use some attribs in Octane. it's... ridiculous.
2) some packed geo -> instance implicit conversion + delayed load procedural support (houdini plugin)
3) disc primitive for points, curve primitive (tube, strand)
4) volumes - be able to sample parameters of the shader from a field. i would appreciate having checkbox with "Slows down your render considerably" instead of "not implemented for perfomance reasons" hint in manual.
special cases:
- vector field to color density field
- 2 scalar fields for density and emission (heat and temperature)
5) nested dielectrics
bloomendale_1
Postby Despot » Sun Nov 18, 2018 5:53 pm
Despot Sun Nov 18, 2018 5:53 pm
Goldorak wrote:On the todo list
That's music to my ears (that's if your reply was in answer to my bloom threshold request).
Any idea if this will be in Octane 4 or 2018 ?
J
Despot
Postby MistAjuliax » Mon Dec 03, 2018 9:08 am
MistAjuliax Mon Dec 03, 2018 9:08 am
Any chance to have an octane 4.0x version to get issues solved and have minor improvements and new features ?? I need a new pass : a normal volume pass to get lighting in game engine with sprite sheets from fire/ smoke effect ...
Win 10 pro 64 / GTX 1070ti, gtx 1070 / FX8320E / 16Go DRR4
MistAjuliax
Postby Goldorak » Wed Dec 05, 2018 6:51 am
Goldorak Wed Dec 05, 2018 6:51 am
bloomendale_1 wrote:i'm new to Octane so only most important)
special cases:
We are focusing heavily on Houdini features and support with v2018.1+
viewtopic.php?f=15&t=69461&p=350213#p350213
Goldorak
Postby Goldorak » Wed Dec 05, 2018 6:52 am
Goldorak Wed Dec 05, 2018 6:52 am
MistAjuliax wrote:Any chance to have an octane 4.0x version to get issues solved and have minor improvements and new features ?? I need a new pass : a normal volume pass to get lighting in game engine with sprite sheets from fire/ smoke effect ...
4.01 is nearly done, but all new features are going into 2018.1 (see post above), and 2019.x
Goldorak
PreviousNext
Return to General Discussion
Users browsing this forum: No registered users and 18 guests
Tue Apr 23, 2024 8:39 pm [ UTC ]
