3ds max export on latest version
Forums: 3ds max export on latest version
Postby BenterA » Mon May 21, 2018 4:45 pm
BenterA Mon May 21, 2018 4:45 pm
Hi guys,
usally i tend to stay in 3ds Max, when renderding in Octane, but now i have to rendern an animation in the Standalone Version as SA seems to handle the amount of geometry much better/ more stable.
I know it worked in older versions, so did anything change when it comes to exproting animated cameras (Octane Camera in Max)? All objects exports work fine but i can`t find a way to get my camera animation into the SA?
Thanks in advance
Ben
BenterA
Re: 3ds max export on latest version
Postby paride4331 » Tue May 22, 2018 7:50 am
paride4331 Tue May 22, 2018 7:50 am
Hi BenterA,
Octane for 3dsmax 5.08 has an animated .abc camera issue already reported to developers.
Workaround is exporting animated camera to .abc then importing separately into SA.
3dsMax > export selected > .abc
Win 7 / i7 5930 - 32gb / 1 x quadro K620 / 2 x Evga Titan X Hybrid
paride4331
Postby BenterA » Tue May 22, 2018 9:01 am
BenterA Tue May 22, 2018 9:01 am
Thanks for your answer!
I tried to import the Camera seperately as an alembic. But unfortunately the Cam Node does not have any inputs to connect it? Do you know what the reason behind that could be?
Many Thanks
Ben
BenterA
Postby paride4331 » Tue May 22, 2018 10:31 am
paride4331 Tue May 22, 2018 10:31 am
Hi BenterA,
right mouse button select > ungroup
paride4331
Postby BenterA » Thu May 24, 2018 7:44 am
BenterA Thu May 24, 2018 7:44 am
Thanks paride,
you mean the camera node (i imorted it as Geometry-Scene). Unfortunately there is no "ungroup" option in the right click menu.
BenterA
Postby paride4331 » Thu May 24, 2018 8:25 am
paride4331 Thu May 24, 2018 8:25 am
Hi BenterA,
I must have misunderstood, attached a screenshot.
paride4331
Postby BenterA » Thu May 24, 2018 5:56 pm
BenterA Thu May 24, 2018 5:56 pm
Thank you for you help! I have tried it this way, too. But as you can see, there is just no way to connect it.
BenterA
Postby paride4331 » Thu May 31, 2018 8:16 am
paride4331 Thu May 31, 2018 8:16 am
Hi BenterA,
Did you try 5.09, .abc camera was fixed.
paride4331
Postby BenterA » Sat Jun 02, 2018 2:01 pm
BenterA Sat Jun 02, 2018 2:01 pm
Thanks a lot, works fine now!! :)
BenterA
Users browsing this forum: No registered users and 7 guests
Sat Feb 29, 2020 5:04 am [ UTC ]
