OctaneRender 3 for Modo [OBSOLETE]
Forums: OctaneRender 3 for Modo [OBSOLETE]
Re: OctaneRender 3 for Modo [TEST and STABLE]
Postby face_off » Fri Apr 13, 2018 5:40 am
face_off Fri Apr 13, 2018 5:40 am
I have updated the WINDOWS TEST installer at the top of this thread with:
3.08.0.130
- Compiled with Octane 3.08 RC4
I will provide OSX and Linux builds with the next Octane 3.08 RC release.
Postby Paulbrownv » Sat Apr 21, 2018 6:01 am
Paulbrownv Sat Apr 21, 2018 6:01 am
Question: We used to be able to get separate meshes when exporting to ORBX if there was no animation. Now we always get everything packed into a .abc geo node. Is there a way to keep objects separate when there is no animation?
I've seen this implemented in C4D where they get an option when they choose to export to standalone.
Paulbrownv
Postby Fredrikvictorhugo » Sat Apr 21, 2018 9:07 pm
Fredrikvictorhugo Sat Apr 21, 2018 9:07 pm
Hi.
Im having problem when tweaking material in modo 12.1v1 beta when Octanerender Viewport running 3.08.0.130. The material wont update..
The only way for the material to update is too move the mesh.. Bug?
And when modeling in modo 12.1v1 the model wont update in Octanerender Viewport.
It works in modo 12.0v1
/Fredrik
Fredrikvictorhugo
Postby face_off » Sun Apr 22, 2018 7:36 am
face_off Sun Apr 22, 2018 7:36 am
There is not currently any way to do this in the Modo plugin. All objects are wrapped into an .ABC file.
This looks like a Modo bug. I will download 12.1v1 and take a look, however it's something you should bug with Foundry.
Postby funk » Sun Apr 22, 2018 11:50 am
funk Sun Apr 22, 2018 11:50 am
Fredrikvictorhugo wrote:Hi.
/Fredrik
Materials seem to be updating OK here. Can you explain what youre doing?
I have noticed that editing gradients no longer update in real time though. This seems to be broken in both vray and octane
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby v1adut » Sun Apr 22, 2018 12:07 pm
v1adut Sun Apr 22, 2018 12:07 pm
Hi guys, I found a bug in octane 3.08.127... it was there before.
When I am parenting geometry to an animatable locator, the geo parented does not move with the locator in some condition, and the render remains behind.
v1adut
Postby Fredrikvictorhugo » Mon Apr 23, 2018 6:33 pm
Fredrikvictorhugo Mon Apr 23, 2018 6:33 pm
Ok I confirmed when I pushing polygons on a mesh when octane running the viewport doesent update the change with modo 12.1v1.
Only if I reload the scene in to the octane viewport.
And I have live geometry update on.
Someone else having the same problem?
The thing about materials seems to work.
/ Fredrik
Fredrikvictorhugo
Postby funk » Mon Apr 23, 2018 6:46 pm
funk Mon Apr 23, 2018 6:46 pm
Yes it seems live mesh edits are broken. Its also broken in vray
funk
Postby janurschel » Tue Apr 24, 2018 5:08 am
janurschel Tue Apr 24, 2018 5:08 am
Running Modo 12.0v1 with Octane plugin 3.8.0.129 on MacOS High Sierra 10.13.3 and when the plugin is activated all FBX/OBJ file imports crash modo instantly. No matter the file (all have verified to be working on the same machine in different 3D packages). When Octane plugin is installed and activated Modo crashes. If I turn the plugin off the import works fine.
Any idea whats going on there?
janurschel
Postby face_off » Tue Apr 24, 2018 5:14 am
face_off Tue Apr 24, 2018 5:14 am
This is a known issue, which I have reported to Foundry, and they have been able to reproduce. You will need to go back to Modo11, and contact Foundry to let them know how important this issue is to get fixed.
Thank
PreviousNext
Return to Foundry Modo
Users browsing this forum: No registered users and 24 guests
Thu Apr 25, 2024 1:46 pm [ UTC ]
