color graident emission color
Forums: color graident emission color
Houdini Integrated Plugin
Postby FahadA92 » Sat Apr 07, 2018 5:58 am
FahadA92 Sat Apr 07, 2018 5:58 am
Hi! I'm trying to render curve lines as light source. the color is in the Cd attrib. I tried the pack color attrib in the uv map in the fur option but there doesn't seem to be similar option for the emission color.
Windows 8.1, GTX 970 EVGA SC, i7 4790k, 32GB RAM
FahadA92
Re: color graident emission color
Postby juanjgon » Tue Apr 10, 2018 11:14 pm
juanjgon Tue Apr 10, 2018 11:14 pm
You can use the same pack color attrib in the uv map workflow with a texture emission node linking the texture map to the texture emission node "Efficiency" input, but the problem here is that I think that the curve primitives can't work as emissive surfaces. You can enable the texture emission node "Surface brightness" parameter to see the hair colors, but the curves don't cast real light to the scene.
juanjgon
Return to Houdini
Users browsing this forum: No registered users and 13 guests
Tue Apr 23, 2024 2:37 pm [ UTC ]
