Skyboxes
Forums: Skyboxes
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
Skyboxes
Postby ahrenm » Tue Feb 13, 2018 2:45 am
ahrenm Tue Feb 13, 2018 2:45 am
Hi there,
Is there any guidance on how to set Skyboxes? I've tried setting a skybox asset to the "Skybox Mat" property of the PBR Render target but it doesn't show up in the render.
A.
ahrenm
Re: Skyboxes
Postby Maikel » Thu Feb 15, 2018 3:36 pm
Maikel Thu Feb 15, 2018 3:36 pm
It should work by simply assigning a skybox in Unity's Lighting panel, but there appears to be an issue with this... Thanks for pointing this out, we're looking into it!
In the meantime, can you see if this solves your problem?:
- Go to the PBR Render target and, under Environment, set "Select environment settings"-dropdown to "Render Target";
- Assign a new or existing skybox material;
- Make sure the Texture dropdown is set to "Texture";
- Assign your skybox image there.
Win 7 64 | Geforce GTX680 | i7 2600K | 16GB
Maikel
Re: Skyboxes
Postby ahrenm » Sun Feb 18, 2018 9:37 pm
ahrenm Sun Feb 18, 2018 9:37 pm
Converting the Skybox to a pano, certainly fixed the problem. I found one tool that could do it, but not without issues.
https://www.youtube.com/watch?v=LcQb3UDDgQ4
Front to back orientation is still wrong in this grab, so it would take rotating the up/down images 180 and then sliding the side images around 2 spots.
Anyway, I'm happy with this as a workaround for now. :-)
A.
ahrenm
Return to Octane for Unity
Users browsing this forum: No registered users and 11 guests
Tue Apr 23, 2024 7:44 pm [ UTC ]
