Alembic and Motion Blur
Forums: Alembic and Motion Blur
Houdini Integrated Plugin
Postby tschwenke » Wed Jan 24, 2018 4:13 pm
tschwenke Wed Jan 24, 2018 4:13 pm
When I export via ROP Alembic node, I see a "Motion Blur" tab. However, if I import this Alembic file to Octane Standalone, it doesn't seem to have an impact on the MB feature in Octane. What does this "Shutter" mean? It doesn't seem to do anything in Octane.
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Re: Alembic and Motion Blur
Postby juanjgon » Wed Jan 24, 2018 9:33 pm
juanjgon Wed Jan 24, 2018 9:33 pm
I'm not sure about how the Standalone works with animated alembic files, or alembic files with motion blur. The alembic ROP motion blur options can be related only to the SOP level mesh deformations motion blur.
If you have the Houdini plugin, you could try to export the scene as an .orbx file using the export options available in the Octane ROP.
juanjgon
Postby tschwenke » Sat Feb 03, 2018 10:49 pm
tschwenke Sat Feb 03, 2018 10:49 pm
Thanks alot! :)
tschwenke
Postby tschwenke » Sat Feb 10, 2018 10:11 pm
tschwenke Sat Feb 10, 2018 10:11 pm
I really go nuts here :/
When it comes to the Houdini plugin, is it possible to import an ORBX file? And does motion blur work in Houdini? I usually work with Carrara, but motion blur of rotating objects - like car tires - aren't working in the Carrara plugin.
Best wishes,
Thomas
tschwenke
Postby juanjgon » Sun Feb 11, 2018 5:08 pm
juanjgon Sun Feb 11, 2018 5:08 pm
Nope, sorry, the Houdini plugin can't render .orbx files, but it should render any kind of motion blur without problems, including the camera, object transformations, object deformations at SOP level, instances, particles, etc.
If you have problems with the motion blur in a scene, can you please send it to me to check it here?
Thansk,
juanjgon
Postby tschwenke » Mon Feb 12, 2018 9:26 pm
tschwenke Mon Feb 12, 2018 9:26 pm
It's not a Houdini Plugin problem, but a Carrara Plugin problem. But thank you though!
Best wishes,
Thomas
tschwenke
Return to Houdini
Tue Apr 23, 2024 11:40 pm [ UTC ]
