Istance range node 3dMax
Forums: Istance range node 3dMax
Tutorials for OctaneRender - demonstrations and howto's.
Postby paride4331 » Thu Nov 30, 2017 1:32 pm
paride4331 Thu Nov 30, 2017 1:32 pm
Hi guys,
new istance range node (3.07 SDK)
Win 7 / i7 5930 - 32gb / 1 x quadro K620 / 2 x Evga Titan X Hybrid
paride4331
Re: Istance range node 3dMax
Postby coilbook » Thu Nov 30, 2017 8:13 pm
coilbook Thu Nov 30, 2017 8:13 pm
paride4331 wrote:Hi guys,
thanks. Would be nice to have instance on subobject level of one object.
Also please add an option to lock dirt texture to subobject level so objects near it wont create more dirt on it (for example, more dirt on the bottom of the wheel (with dirt texture) because it touches the ground)
coilbook
Postby HHbomb » Fri Dec 01, 2017 5:04 pm
HHbomb Fri Dec 01, 2017 5:04 pm
Hi , Paride. Using instance range I have strange artifacts. Bug or not bug ?
OCT_pb_instrange.zip
(39.43 KiB) Downloaded 71 times
| seven 64 | i7 5930K + titanX + 1050 for video | i7 3970 + 4 x titan | i7 5960 + 4 x titanX | 3dsmax 2018 |
HHbomb
Postby Rik » Mon Dec 04, 2017 7:04 am
Rik Mon Dec 04, 2017 7:04 am
[OK well this is frustrating. What am I doing wrong Paride?
I have also set the max id to 47 as per your image.
attachment=0]instance range fail.jpg[/attachment]
Rik
Postby Rik » Mon Dec 04, 2017 7:08 am
Rik Mon Dec 04, 2017 7:08 am
Rik
Postby paride4331 » Mon Dec 04, 2017 2:43 pm
paride4331 Mon Dec 04, 2017 2:43 pm
Hi Rik,
meanwhile attach file test, I hope they help you.
01-random.zip
(749.04 KiB) Downloaded 76 times
02-gradient.zip
(748.98 KiB) Downloaded 76 times
paride4331
Postby paride4331 » Mon Dec 04, 2017 3:07 pm
paride4331 Mon Dec 04, 2017 3:07 pm
Hi HHbomb,
here for you,
(41.64 KiB) Downloaded 71 times
paride4331
Postby Rik » Mon Dec 04, 2017 3:25 pm
Rik Mon Dec 04, 2017 3:25 pm
Thanks.
Nothing was changing until I turned the octane proxy tick off then on again. Is this a feature?
Still don't know what's going on though.
What's maximum id in the instance map? What number does it represent?
What should the start and stop be in the oct obj properties? Is it related to the number of objects the material is applied to?
Buggered if I can see me getting instances of proxy trees with random colours on leaves and random variations across the different instances of those proxy trees.
Rik
Postby paride4331 » Wed Dec 06, 2017 9:49 am
paride4331 Wed Dec 06, 2017 9:49 am
Hi Rik,
using 3dsMax array istance (animated GIF)
I apologize for the inconvenience; I think this issue depends on 4.43 version.
Try again using 4.44 which should have fixed it.
paride4331
Postby acc24ex » Sat Dec 09, 2017 5:31 pm
acc24ex Sat Dec 09, 2017 5:31 pm
paride do you write istance on purpose, cause I see it's written as iNstance in the user interface - you did that on every picture and text as well?
[size=85]3dmax, zbrush, UE
//Behance profile //BOONAR
acc24ex
Next
Return to Tutorials
Mon Aug 19, 2019 11:13 pm [ UTC ]
