Replicate Proxy Geometry
Forums: Replicate Proxy Geometry
Postby Hesekiel2517 » Tue Oct 17, 2017 11:26 am
Hesekiel2517 Tue Oct 17, 2017 11:26 am
Hey Paul,
is it possible to use proxy files within a replicator? When i try to scatter the proxy Mesh nothing happens.
PS: It's definitly possible in Standalone i just have to plug the generated Nodegraph to the Scatter Node
Edit: I found a workaround: I make a proxy file with a replicator inside. Works but would be a lot easier if we could use the replicator directly.
Thanks in Advance!
Hesekiel2517
Re: Replicate Proxy Geometry
Postby face_off » Tue Oct 17, 2017 11:57 pm
face_off Tue Oct 17, 2017 11:57 pm
Hi - you are right - Proxy ORBX file support does not currently work in a Replicator, and you need to do it in reverse (ie. have the scatter node inside the ORBX proxy).
Postby Hesekiel2517 » Wed Feb 27, 2019 12:59 pm
Hesekiel2517 Wed Feb 27, 2019 12:59 pm
Hey Paul,
any News about this? Will it be possible to replicate proxys or even instance them? I have some heavy meshes and it's so nice to put them in proxys. But i have to duplicate them over and over again and so i have to decide between multiple proxys or some heavy meshes in my scene.
Thank you in advance!
Hesekiel2517
Postby face_off » Thu Feb 28, 2019 3:03 am
face_off Thu Feb 28, 2019 3:03 am
Hi. Once I get a solid 2018.1 release done I will take a look at this, as it should be reasonably easy to implement. If you haven't seen it in the plugin in the next month, pls give me another prod about it.
Postby Hesekiel2517 » Fri Mar 01, 2019 9:57 am
Hesekiel2517 Fri Mar 01, 2019 9:57 am
Hey Paul, thank you in advance. That sounds great!
Hesekiel2517
Postby Hesekiel2517 » Thu Mar 07, 2019 11:26 am
Hesekiel2517 Thu Mar 07, 2019 11:26 am
Just downloaded the new testbuild: Thank you
That was quick!
Hesekiel2517
Return to Foundry Modo
Thu Apr 18, 2024 10:50 pm [ UTC ]
