Xhed wrote:Could you export the scene as an ORBX file and try rendering it in standalone? I'm curious what the performance is there using the same GPUs.
What resolution and kernel are you for your render? 12 minutes sounds like a long time for a render.
The speed improvement of enabling a 2nd GPU is a little under 100%, due to overhead of adressing the 2nd GPU and the syncing.
The test build is limited in the number of GPUs, we only allow usage of 2. When we release the final product, there will be multiple subscription tiers with different capabilities, where you could enable >2 GPUs for Tier 3.
Sorry to keep bothering you guys. Last clarification on this. When you say "When we release the final product, there will be multiple subscription tiers with different capabilities, where you could enable >2 GPUs for Tier 3.", does that mean the same thing as in the OctaneRender FAQ as stated below? Meaning, we can add as many gpus as we can connect at that point and continue to gain near 100% for each one, or will the Unity version not function the same way as the standalone?
https://home.otoy.com/render/octane-render/faqs/"Yes! Octane Render completely relies on the GPU for rendering performance and scales extremely well. If your motherboard can accept more than one video card, adding additional video cards will greatly improve Octane’s rendering speed because Octane’s performance scales perfectly with the number of GPUs (e.g. rendering with four GTX Titans will be 4x faster than using only 1 GTX Titan), without the need for SLI. The cards can be different models, allowing GPUs from two completely different architectures to be used in a machine with multiple PCI-E slots (such as a GTX 560 in the primary slot and a GTX 780 in the second).
The cost of adding an additional NVIDIA GPU to your system is very low compared to the cost of a small renderfarm of 10 to 15 computers to get the same performance with a CPU based rendering solution."
