Noise on edges of Shadow Passes
Forums: Noise on edges of Shadow Passes
Moderator: aoktar
Postby colinleiker » Sat May 20, 2017 10:07 pm
colinleiker Sat May 20, 2017 10:07 pm
I've tried to find the answer to this myself, but I've looked all over and can't seem to find a solution.
My issue is I get noisey edges when rendering Shadow Passes in the Render Layer system. I've attached a screenshot of my scene showing the issue, as well as my settings.
I've played with every level of samples, specular depth, ray epsilon, caustic blur, GI clamp, and coherent ratio. Nothing gets rid of them. I've done the trick where I fill the scene with a ton of even light and than just reduce the exposure to my desired lighting, but they still appear. Enabling "Only Side Effects" seems to get rid of them, but then it shows shadows behind the objects that I do not want to see. Also it adds weird "scratch marks" in the shadows on the bottom of objects. Also I have no idea wtf this setting is meant for, so I'm hesitant to use it.
Anyone got a clue? Thanks!
octane noise in shadow pass with render layer
colinleiker
Re: Noise on edges of Shadow Passes
Postby aoktar » Sun May 21, 2017 7:15 am
aoktar Sun May 21, 2017 7:15 am
I can't check that detailed but you should check that in a compositing software after comping not in LV or PV. And search for similar topics with answers.
Postby niestudio » Sun May 21, 2017 2:50 pm
niestudio Sun May 21, 2017 2:50 pm
see this thread viewtopic.php?f=30&t=56386&start=10#p301206
Black dots will not show when your shadow layer is underneath your object in compositing.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
niestudio
Postby colinleiker » Thu May 25, 2017 4:30 pm
colinleiker Thu May 25, 2017 4:30 pm
aoktar wrote:I can't check that detailed but you should check that in a compositing software after comping not in LV or PV. And search for similar topics with answers.
Yea when I bring it into AE it just looks the same :/ As I said, I wouldnt be posting here had I not already searched for similar topics haha. Couldn't find anything.
niestudio wrote:see this thread viewtopic.php?f=30&t=56386&start=10#p301206
Unfortunately they are still very noticeable. Especially when I am using a transparent material to generate shadows (example: piece of clear tape peeling off the wall will cast slight shadows, which are completely unusable in Octane as the pixelated edges looks terrible).
colinleiker
Postby bepeg4d » Fri Jun 09, 2017 3:12 pm
bepeg4d Fri Jun 09, 2017 3:12 pm
Hi colinleiker,
I suspect that you are experiencing the same issue reported innthis other discussion, and will be fixed in the next update of SDK:
viewtopic.php?f=30&t=61674#p315608
ciao beppe
Postby Whispermode » Sat Jun 15, 2019 4:39 pm
Whispermode Sat Jun 15, 2019 4:39 pm
Devs - please confirm: this is still a problem, even in 2019.1 XB2, right?
Whispermode
Postby bepeg4d » Wed Jun 19, 2019 3:02 pm
bepeg4d Wed Jun 19, 2019 3:02 pm
The residual internal noise will be covered by the beauty pass on top.
What is important is to have a clean result outside of the alpha of the Render layer, for shadows and reflections.
ciao Beppe
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 8 guests
Mon Mar 08, 2021 12:59 pm [ UTC ]
