Version 3.00 - R1.1 (25.05.2016)
Forums: Version 3.00 - R1.1 (25.05.2016)
Moderator: aoktar
Re: Version 3.00 - R1 (24.05.2016) - Stable version
Postby eyeonestudio » Tue May 24, 2016 9:27 am
eyeonestudio Tue May 24, 2016 9:27 am
Hi aoktar.....Thank For Release
Volume object: First volume filling method by spheres or particles. It's a very experimental and wip feature. Will be improved soon.
I have one Request.
You 'll know what Pyro-Cluster is.
I use for snow(volume). --> Pyro Cluster Sample https://vimeo.com/46344145
See My Stupid Scene(just example)
My Request is
Xparticles +Object Tag(Particle Rendering > single VDB file)
Thanks.. ;)
VOL-PYRO.zip
(81.26 KiB) Downloaded 166 times
CINEMA 4D R2023
Win10 / 10GbE / AMD3995X*2ea, AMD3990X*2ea, 10980XE*2ea / 256Gb RAM / RTX3090*14ea
eyeonestudio
Postby aoktar » Tue May 24, 2016 10:08 am
aoktar Tue May 24, 2016 10:08 am
eyeonestudio wrote:Volume object: First volume filling method by spheres or particles
What is this?
How to apply to scene?
Thanks... First release 3.0 :D
Find attached example scene(volume-anime)
It's still experimental. I'm investigating performance and method.
test rendering with volume+animated noise+spheres
https://vimeo.com/167867146
Postby brasco » Tue May 24, 2016 10:12 am
brasco Tue May 24, 2016 10:12 am
Congratulations on the release Ahmet, thanks for all the hard work!
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
brasco
Postby aoktar » Tue May 24, 2016 11:48 am
aoktar Tue May 24, 2016 11:48 am
brasco wrote:Congratulations on the release Ahmet, thanks for all the hard work!
cheers
brasc
Thanks for support.
Re: Version 3.00 - Beta2.1 (17.05.2016) - Test version
Postby Ron » Tue May 24, 2016 12:04 pm
Ron Tue May 24, 2016 12:04 pm
SOLVED
After installing the final release and deactivating the licence via website it is working again.
Thank you Ahmet for this release! You are awesome!
Ron
Ron wrote:After installing standalone 3 my plugin licence cannot be found. With Beta 2 everything worked fine.
Cannot even deactivate my plugin licence to reactivate it after.
What can I do?
Ron
PS:
I already deleted the otoy_credentials but no success ...
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Ron
Postby aoktar » Tue May 24, 2016 12:11 pm
aoktar Tue May 24, 2016 12:11 pm
Ron wrote:SOLVED
Nice! It was not about plugins. Anyone has problems on running older(V2) versions? It doesn't run one me :(
Postby dinf » Tue May 24, 2016 12:28 pm
dinf Tue May 24, 2016 12:28 pm
aoktar wrote:Anyone has problems on running older(V2) versions? It doesn't run one me :(
Is starting, but I didn't start v3 on C4D so far but standalone 3 only.
After closing a v3 version the license site says "no license running", after closing a v2 license it says (able to) "deactivate". Seems to be as it should be. I'll try C4D later.
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
dinf
Postby Digitalism » Tue May 24, 2016 4:06 pm
Digitalism Tue May 24, 2016 4:06 pm
Just bought my upgrade, thanks :)
Not sure if this is a C4D bug or an Octane bug, but if you have a layout saved (from before you upgraded) it says in the live viewer the old version, not the new version.
Digitalism
Postby aoktar » Tue May 24, 2016 4:10 pm
aoktar Tue May 24, 2016 4:10 pm
Digitalism wrote:Just bought my upgrade, thanks :)
yes big bug! Thanks for report. It's not fixable. Close/open and save to again layout.
Postby jingles » Tue May 24, 2016 4:23 pm
jingles Tue May 24, 2016 4:23 pm
The C4D Plugin requires inputting the license details in accounts/settings, but that area no longer has the option to do so.
What is the solution?
I tried erasing the preference file noted on the installation page. The installation is a clean install (removed 2.25, restarted, installed 3, restarted).
Showcases Octane Standalone connected, but no option in C4D plugin
jingles
PreviousNext
Return to Releases
Users browsing this forum: No registered users and 11 guests
Thu Apr 25, 2024 12:13 am [ UTC ]
