Phantom Node Link [1.2.2] Auto-generate node hierarchies!
Forums: Phantom Node Link [1.2.2] Auto-generate node hierarchies!
Re: Phantom Node Link [in development]
Postby Phantom107 » Mon Apr 04, 2016 12:50 pm
Phantom107 Mon Apr 04, 2016 12:50 pm
Hahaha nice I fell for it, went to look it up in the source :oops: :lol:
Another dev update:
- Software can now take data off your clipboard and store it in the Phantom Node Link library, tied to a scatter object
- The data can also be copied or deleted
- As you can see in the pic, I've expanded the system for feedback to you (the user)
- There are various checks in place that try to detect whether your data is valid. I'm curious to see whether you guys can break it... It can detect a broken XML structure, the Octane version of the node data you copied, whether you use groups within the group (you shouldn't!), and finally it compares the outputs to the variants of that scatter object.
The next step for me is to get back into Phantom Scatter 1.10 and make it detect the XML data entered in Phantom Node Link and then make sure it can actually export it all in 1 go so CTRL+V works in Octane.
Phantom107
Postby Phantom107 » Sun Apr 10, 2016 11:31 pm
Phantom107 Sun Apr 10, 2016 11:31 pm
Success, Phantom Scatter 1.10 can now deal with the Phantom Node Link data:
viewtopic.php?f=9&t=33791&p=269882#p269882
After I create a manual on how to operate it (it's really really easy and convenient) then PNL release 1.0 is a go!
Phantom107
Postby Phantom107 » Wed Apr 13, 2016 3:27 am
Phantom107 Wed Apr 13, 2016 3:27 am
Updated website, Phantom Node Link manual is now available for download so you can check out how I designed this new program.
> Visit the Phantom Node Link section on the Phantom Scatter website!
Phantom107
Re: Phantom Node Link [1.0] Auto-generate node hierarchies!
Postby Phantom107 » Wed Apr 13, 2016 3:30 pm
Phantom107 Wed Apr 13, 2016 3:30 pm
Phantom Node Link 1.0 is now available!
Visit the website here: http://scatter.phantomtechnology.nl/#section-phantom-node-link-software-included
To learn more about Phantom Node Link, download the manual here: http://guusthissen.nl/downloads_node_li ... e_link.pdf
Phantom107
Re: Phantom Node Link [1.0 b] Auto-generate node hierarchies!
Postby Phantom107 » Tue Apr 26, 2016 10:02 pm
Phantom107 Tue Apr 26, 2016 10:02 pm
Phantom Node Link 1.0 b is now available!
» Implemented a check that detects whether scatter objects were found in C:\Phantom Scatter\library and closes the program when it didn't find any, instead of crashing.
Phantom107
Postby Phantom107 » Wed Apr 27, 2016 2:41 pm
Phantom107 Wed Apr 27, 2016 2:41 pm
Phantom Node Link 1.0 c is now available!
» Fixed problem that caused a program crash when the scatter object library did not exceed the visible screen space.
Phantom107
Re: Phantom Node Link [1.0 c] Auto-generate node hierarchies!
Postby Phantom107 » Thu Apr 28, 2016 5:33 pm
Phantom107 Thu Apr 28, 2016 5:33 pm
Updated the manual, hope it's more clear for you guys now: http://guusthissen.nl/downloads_node_li ... e_link.pdf
Phantom107
Postby Phantom107 » Mon May 16, 2016 8:10 pm
Phantom107 Mon May 16, 2016 8:10 pm
Phantom Node Link 1.0 d is now available!
» Added screen bending to the UI to make the graphics more in line with the other Phantom products.
» Added function CURVE to the (newly added) module MAIN. This allows you to disable the UI bending if you don't like this.
» Added function INFO TEXT COLOR under MAIN, this makes the function info text display in white instead of the default (purple). This makes it easier to read on lower-spec displays.
» Minor performance improvement when the program is idle.
Phantom107
Re: Phantom Node Link [1.0 e] Auto-generate node hierarchies!
Postby Phantom107 » Sat May 21, 2016 7:03 pm
Phantom107 Sat May 21, 2016 7:03 pm
Phantom Node Link 1.0.5 is now available!
» Minor internal fix.
» Program now correctly shows up as 'Phantom Node Link' in task manager.
Phantom107
Re: Phantom Node Link [1.0.6] Auto-generate node hierarchies!
Postby Phantom107 » Sun Sep 18, 2016 4:30 pm
Phantom107 Sun Sep 18, 2016 4:30 pm
Phantom Node Link 1.0.6 is now available!
» Expanded UI to accomodate the UNIQUE PER TRIANGLE feature under VARIANTS for PER TRI-scatter in Phantom Scatter 1.10.11.
Phantom107
PreviousNext
Return to General Discussion
Users browsing this forum: No registered users and 9 guests
Fri Apr 19, 2024 4:15 am [ UTC ]
