Share materials
Forums: Share materials
Moderator: BK
Re: Share materials
Postby DrHemulen » Mon Nov 30, 2015 7:26 pm
DrHemulen Mon Nov 30, 2015 7:26 pm
Those are some serious in-depth posts man! Thanks a lot!
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
DrHemulen
Re: Share materials
Postby sikotik13 » Tue Dec 01, 2015 1:02 am
sikotik13 Tue Dec 01, 2015 1:02 am
Having issues with my render rig at the moment, and TeamViewer is being a pain.
Just to cover bases (since they may have changed on me, someone who can actually run Daz Studio properly should also verify if the options for map priority are still functional (they were in 1.2, hadn't thought to check in 2.* as I was still using mostly templates from 1.2 primarily). This particular one, last time I used it as-is, auto used the map in the diffuse slot for screens (like monitors, tvs, etc.) without issue. If this has changed, it is new behavior, and I can't remember the default template settings, but I think it is set to none. You have to actually select the templated node in NGE to see this section, it doesn't show up anywhere but there (the green one highlighted in my NGE is the actual image input node I templated in the material). If this is set to some other map or none (or static, since that keeps whatever it is, and ignores maps entirely), that would cause the same issue. Just crossed my mind on reading this quite informative post.
Looking at it again, the node organization was thrown off by 2.* when it was first prereleased. It added an extra, useless mix node for whatever reason to anything templated, which I vaguely recall reporting to t_3 early on. I clearly never fixed it myself either for this one, but the material still functioned fine regardless in prerelease 4 or 5, whichever was last before face-off took over. I do remember some back and forth with him about templates in general, and that was when I started playing around with settings in NGE more, but it's been quite a while, so I'm a little fuzzy on some of the details. Hope it helps out a little, at least, and once again, thanks for taking so much time to educate others on stuff, linvanchene :).
| Intel i7-5960x @ 3.8 GHz| ASUS X99-E WS | 64 GB G.Skill DDR4 2400 Ram | 4x EVGA GTX 980 Ti | Win10 Professional x64 | Watercooled
sikotik13
Re: Share materials
Postby face_off » Tue Dec 01, 2015 2:40 am
face_off Tue Dec 01, 2015 2:40 am
I have not had time to absorb the contents of this thread so far. If there is a bug that I need to know able, pls report it in the 2.24.2 thread with details.
Re: Share materials
Postby abayliss » Tue Dec 01, 2015 3:20 am
abayliss Tue Dec 01, 2015 3:20 am
Not sure I've read linvanchene's post correctly, but whenever I have an issue with the maps in a applied OcDS material template not matching the maps in Daz Studio, I right click the surface in question in the OcDS Material's tab, or the parent object when it's multiple surfaces, and select the corresponding 'Replace Map' option, for instance 'Replace Diffuse Maps'.
I use this a lot to speed up the workflow when using Redspecc shaders, first I apply a generic material preset that applies the correct Redspecc shaders templates to all the figure surfaces, then I'll apply a material preset for the actual character material that I want. I'll then right click on the figure in the OcDS Material's tab and select 'Replace Diffuse Maps' and then 'Replace Bump Maps' which then updates all the diffuse maps and bump maps in the OcDS Redspecc shaders template surfaces to the ones I just applied to the figure in Daz.
Windows 10 Pro 64bit, i7-8700 3.2 GHz, 64GB RAM
2 x RTX 2080ti
abayliss
Workflows with templates and the "Replace maps" feature
Postby linvanchene » Tue Dec 01, 2015 5:12 am
linvanchene Tue Dec 01, 2015 5:12 am
sikotik13 wrote: If this is set to some other map or none (or static, since that keeps whatever it is, and ignores maps entirely), that would cause the same issue.
I double checked if adding a checkmark at "Keep previous if no new map was found" would change anything.
No luck with that.
I guess we may find solutions or other limitations when more people start using templates and are trying to save them as DAZ Studio material presets.
abayliss wrote:Not sure I've read linvanchene's post correctly, but whenever I have an issue with the maps in a applied OcDS material template not matching the maps in Daz Studio, I right click the surface in question in the OcDS Material's tab, or the parent object when it's multiple surfaces, and select the corresponding 'Replace Map' option, for instance 'Replace Diffuse Maps'.
Thank you so much abayliss!
I did not remember the "Replace maps" features included when right clicking surfaces.
Replace maps - simple template material workflow
The "Replace maps" feature makes it possible to work around the limitations when saving OctaneRender materials with template nodes as DAZ Studio material presets.
- 001 OR material after auto conversion
002 applied DAZ Studio material with template node
003 right click option - Replace all active maps
004 End result - template material combined with map in DAZ Studio surface tab
004 End result - template material combined with map in DAZ Studio surface tab.jpg
Creating a DAZ Studio material preset with templates on multiple surface zones
Now we can combine once again everything already discussed to create a material preset that includes multiple surfaces and templates.
Instead of dragging over RedSpecTGX user presets from materials to surfaces in the OcDS tab
you can
- click on the saved RedSpecTGX DAZ Studio material preset
- select all surface zones in OcDS
- right click and "Replace all active maps"
The following workflow may take some time to set up the material preset for the first time.
But once that is done it can be used very quickly in the future:
001 apply Genesis 3 Female RedSpecTGX to all surface zones:
002 use the clear texture right click option to remove all applied textures from the template nodes:
002 use the clear texture right click option to remove all applied textures from the template nodes.jpg
Step 002 may be optional.
003 save as material preset - make sure to only select the option "tags" on each surface zone
Now create a new scene with any new character
004 apply DAZ Studio material preset
005 DAZ Studio material presets including empty template nodes loaded
006 Use CTRL +A to select all surface zones and right click the selection and choose "Replace all active maps"
007 character specific maps loaded
k, I guess that covers it!
Special thanks to
abayliss for bringing up the Replace maps feature!
DrHemulen for motivating me to have a closer look at templates!
Elele for asking the right question to get this started!
Notiusweb for actually reading through this all and giving me the impression that my lengthy posts actually helped!
sikotik13 for motivating me to have a closer look at saving DAZ Studio material presets!
TRRazor for providing us with RedSpecTGX OctaneRender shaders!
Thank you all for reading and helping out!
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
Re: Share materials
Postby sikotik13 » Tue Dec 01, 2015 6:52 am
sikotik13 Tue Dec 01, 2015 6:52 am
Glad I could help with motivation :D
When I have the chance (and my computer stops being a pain), I'll try to go through some of my saved stuff. I'm nearly positive I have a few materials I saved as Daz presets that at least used to function correctly, but it's certainly worth verifying, and possibly cross checking with older versions of the plugin to see if/when it went awry, and what I did for those if they are still working correctly. I'll try to get to it no later than this weekend (classes are ramping up for finals in two weeks).
Thanks to linvanchene for putting together excellent tutorials in the meantime :)
sikotik13
Re: Share materials
Postby beat578 » Thu Dec 03, 2015 11:24 am
beat578 Thu Dec 03, 2015 11:24 am
Linvanchene you completely ruined my weekend....
Saturday I will need to read your post and the next day I will feel stupid while trying to understand just half of it...
Never mind.
THANK YOU! Thats an amazing amount of good information and I think it's worth trying to understand it, cause it will take the
renders to a new level once you understood the concept behind it all!
Your guys are great and pushing the Plugin into new heights with all those inputs.
beat578
Re: Share materials
Postby TRRazor » Thu Jun 02, 2016 4:43 am
TRRazor Thu Jun 02, 2016 4:43 am
Sorry for reviving this thread after almost half a year, but I think people should know, that the above mentioned procedure effectively leaves the shaders in a "broken" state.
Thanks linvanchene for diving this deep into the code :)
There is a problem with this procedure, though.
When using the command "Replace all active maps" DAZ Studio does just that, and since the new figure doesn't carry any SSS maps (which RedSpec SSS needs to function properly)
The SSS map channel is being cleared, leaving it empty.
We're currently working on another solution which should simplify the application process in a similar way.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
TRRazor
Re: Share materials
Postby linvanchene » Thu Jun 02, 2016 6:18 am
linvanchene Thu Jun 02, 2016 6:18 am
TRRazor wrote:Sorry for reviving this thread after almost half a year, but I think people should know, that the above mentioned procedure effectively leaves the shaders in a "broken" state.
Update / Edit:
It indeed seems that the "replace active maps" feature has some side effects users might not expect when used in combination with templating.
I will make a new thread for those interested in discussing the current functionality and limitations of templating.
Update / Edit 2:
It seems in order to have the intended result of not updating all map slots when using the "replace active maps" function one has to add all maps that should remain unchanged to a template node with "STATIC dont replace with loaded content" activated.
compare:
viewtopic.php?f=44&t=54497
Btw:
TRRazor wrote:We're currently working on another solution which should simplify the application process in a similar way.
Who exactly do you mean by "we"?
Are you working together with Otoy on this so all DAZ3D artists can then use that solution?
or
Do you mean the Redspec team is just looking for a solution for their own products?
If Otoy is interested in more artists creating products with OctaneRender materials this whole process I described in so many words may need to become a lot simpler.
linvanchene
Re: Share materials
Postby TRRazor » Thu Jun 02, 2016 7:08 am
TRRazor Thu Jun 02, 2016 7:08 am
hmmm. I now have looked at this for another hour....
Are you sure that the issue is with the procedure and not with the way YOU set up the RedSpec SSS shaders?
I've never said that the procedure is the problem - I've said that the procedure currently leaves the shaders in a broken state.
And yes, that is because how we've set them up. Back in the day, when we released the first version of RedSpec, it was very clear that a complete integration within DAZ Studio was merely impossible (hence the dragging and dropping of materials in the OctaneRender menu).
But because OCDS has matured we're now in the position were we can make the dragging and dropping of materials obsolete and instead will offer a solution that will be far more integrated within DAZ Studio and very similar to the way you've described above. In addition to that it will be more convenient for the end user and faster on top of that.
All currently released shaders will receive a free update to include this.
Are you saying that the command "Replace all active maps" is really replacing ALL maps and not just those which are in a template node?
If this is the case (and from my research last week it seems like it is) we have to come up with something more sophisticated.
We do - however - have a solution for that as well.
Witpapier and I - the RedSpec team essentially. Should we need things changed or tweaked in the plug-in, we're in permanent contact with Paul (face_off).
An applicable solution shouldn't be too far away.
This is exactly what we're aiming for.
No, we're looking to find a solution every artist can easily employ and integrate into her/his workflow. We've tried to do it like that in the past and will continue to do so.
I agree with you - and I think this process and some more work in the future will lead to this eventually :)
TRRazor
PreviousNext
Return to DAZ Studio
Wed Apr 24, 2024 2:25 pm [ UTC ]
