Hi Paul,
Thank you for your reply.
Problem Solved.
Zaheer
face_off wrote:Hi Jeroen - that is the status text for the OpenGL addon, not the Octane addon. If you select the OctaneRenderForArchiCAD_Renderer addon, what text is displayed pls?
Thanks Jeroen. What build of AC19 are you using pls? Is it possible you installed the AC18 version of the plugin into AC19? If so, you need to install the AC19 version.Oops, brainfailure
New one here.
face_off wrote:Thanks Jeroen. What build of AC19 are you using pls? Is it possible you installed the AC18 version of the plugin into AC19? If so, you need to install the AC19 version.Oops, brainfailure
New one here.
What build number of AC19 are you using pls?Checked, even reinstalled, but the same.
(The plugin works though)
Users browsing this forum: No registered users and 7 guests
