Viewport colors for objects in Octane for Blender plugin?
Forums: Viewport colors for objects in Octane for Blender plugin?
Postby Nennig » Sun Aug 02, 2015 1:30 pm
Nennig Sun Aug 02, 2015 1:30 pm
Hi there,
Is it possible to add a color to the objects in the viewport ?
This would be so helpfull for crowded scenes.
Thank you
Best regards
Marc
Nennig
Re: Viewport colors for objects in Octane for Blender plugin?
Postby grimm » Sun Aug 02, 2015 5:51 pm
grimm Sun Aug 02, 2015 5:51 pm
That is a Blender question, which was discussed at length in this thread on the Blender Artists site:
http://blenderartists.org/forum/showthr ... -Wireframe
Linux Mint 19 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 440.44
grimm
Postby aufwind » Mon Aug 03, 2015 7:48 am
aufwind Mon Aug 03, 2015 7:48 am
hi,
I added a view lines of code to the octane ui.py a while ago to get colered objects
in the Viewport. You can even have transparency in object mode.
The Viewport Color is independent from the Material Color.
The Color will be visible in Viewport Shading Mode Solid and Textured.
It's best to set the Type to solid as shown in the picture.
I wasn't able to upload the changed script.
You have to manually change the script in the folder: 2.75 / scripts / addons / octane / ui.py
Place the lines beneath as shown in the picture and save the changed script.
class OctaneMaterial_PT_settings(OctaneButtonsPanel, Panel):
    bl_label = "Viewport Material Color"
    bl_context = "material"
    bl_options = {'DEFAULT_CLOSED'}
    @classmethod
    def poll(cls, context):
        return context.material and OctaneButtonsPanel.poll(context)
    def draw(self, context):
        layout = self.layout
        mat = context.material
        obj = context.object
        obj_type = obj.type
        split = layout.split()
        col = split.column()
        col.prop(obj, "draw_type", text="Type")
        if obj_type == 'MESH' or (obj_type == 'EMPTY' and obj.empty_draw_type == 'IMAGE'):
            col.prop(obj, "show_transparent", text="Transparency")
        col.prop(mat, "diffuse_color", text="")
        if context.object.show_transparent:
           col.prop(mat, "alpha")
aufwind
Postby Nennig » Mon Aug 03, 2015 8:24 am
Nennig Mon Aug 03, 2015 8:24 am
Hi aufwind,
This is awesome!
Many thanks for sharing your script. I will try it out tonight after work.
Have a great day.
Marc
Nennig
Postby Nennig » Mon Aug 03, 2015 5:09 pm
Nennig Mon Aug 03, 2015 5:09 pm
Hi aufwind,
Your script works like a charm! Many thanks for sharing !!!!
This is a really cool feature, awesome job.
Marc
Nennig
Postby J.C » Mon Feb 11, 2019 9:11 am
J.C Mon Feb 11, 2019 9:11 am
Dear devs, why dont you add this by default? It's so much useful and easy to add.
CPU – i7 8700k 4.8Ghz + 64GB RAM, GPUs: 2xRTX 2080, 2xGTX 980 Ti.
System – Windows 10, Octane 4-2020, Blender Plugin 17.x-21.x
J.C
Return to Blender
Sat Feb 22, 2020 3:41 am [ UTC ]
