OctaneVR / Lightwave
Forums: OctaneVR / Lightwave
Postby KVNOODLES » Sat May 30, 2015 8:28 pm
KVNOODLES Sat May 30, 2015 8:28 pm
Hi everyone,
I am using Octane Render 2.2 for Lightwave 2015.
Is it possible to run Octane VR Demo in Lightwave?
I've only been able to use Octane VR standalone so far.
Thanks for your help!
KV I NOODLES
www.noodles.link
System: Windows 7 64-bit
CPU: Intel i7 8-Core 3.0 Ghz
GPU: GeForce Titan Z (x2)
RAM: Corsair Vengeance LPX 64GB (8 x 8GB) DDR4 DRAM 2666MHz
KVNOODLES
Re: OctaneVR / Lightwave
Postby ristoraven » Sun May 31, 2015 1:33 pm
ristoraven Sun May 31, 2015 1:33 pm
If you have Octane for LW license you have already everything.
Octane VR is meant for noobs to try out all this magnificent awesomeness for the Metaverse contest.
ristoraven
Postby juanjgon » Mon Jun 01, 2015 8:18 am
juanjgon Mon Jun 01, 2015 8:18 am
Yes, you only need to download the last version. It has the cubic projection in the panoramic camera needed to render the VR scenes.
viewtopic.php?f=36&t=46205
In the panoramic camera you can set the camera type to "Cube Map", set the Fov angles to 360x180, enable the "Keep Upright" option and set the Stereo Output to "Side by Side". Also you need to set the camera resolution to 18432x1536. Attached you have a capture of this settings.
juanjgon
Users browsing this forum: No registered users and 11 guests
Tue Apr 23, 2024 6:56 am [ UTC ]
