OctaneRender® for 3ds max® v2.06
Forums: OctaneRender® for 3ds max® v2.06
Re: OctaneRender® for 3ds max® v2.06
Postby Karba » Thu Aug 28, 2014 7:41 pm
Karba Thu Aug 28, 2014 7:41 pm
darkline wrote:Perhaps I'm not being clear.
The titan Vram clearly says 5.(something) GB avaiable in the octane window, but render fails everytime my Vram exceeds 3GB. The only thing I can think of is that I have a 3GB 580 in the system too (even though it's disabled in octane device panel). This did not occur in Octane 1.x
How many triangles does the scene contain (render statistic)?
Karba
Postby darkline » Sat Sep 20, 2014 3:00 pm
darkline Sat Sep 20, 2014 3:00 pm
in Max viewport Polys : 33,630,772
Verts : 20,524,091
Octane window fails all the time in 2.x but not in 1.x
In failed octane window it says primitives/meshes : :26453554/24
this scene opens in octane 1.55 with no problems
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
darkline
Postby darkline » Sat Sep 20, 2014 3:07 pm
darkline Sat Sep 20, 2014 3:07 pm
For info, if I disable some of the layers I can get the scene to load into octane. for example
Max viewport polys : 16,670,772
Verts : 9,924091
Octane stats at this point :
Mem 1.56/5.533GB Primitives/Meshes 9493554/22
Once I go over the 3GB mark by enabling more layers, it will fail.
darkline
Postby oguzbir » Thu Oct 02, 2014 8:48 am
oguzbir Thu Oct 02, 2014 8:48 am
darkline wrote:For info, if I disable some of the layers I can get the scene to load into octane. for example
Verts : 9,924091
Did you take in account of the frame buffer size?
What happens if you render it say 640x480 with high poly.
My Portfolio
oguzbir
Postby darkline » Fri Oct 03, 2014 9:34 am
darkline Fri Oct 03, 2014 9:34 am
Will try that, but I know that the render resolution is the same in both octane v1 and v2 tests (same max file).
darkline
Previous
Return to Releases
Users browsing this forum: No registered users and 5 guests
Thu Apr 25, 2024 9:26 am [ UTC ]
