more procedurals
Forums: more procedurals
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
more procedurals
Postby radiance » Sun May 23, 2010 1:30 pm
radiance Sun May 23, 2010 1:30 pm
Hey,
i added a handfull of handy procedurals to get us started with RC3 coming out at the end of the day. ;)
some examples attached.
these use only a few kilobytes of GPU memory and use can use as much as you want ;)
procedurals now also work on bump.
all attachements use only procedurals, no imagemaps.
Radiance
radiance
Re: more procedurals
Postby GeorgoSK » Sun May 23, 2010 3:36 pm
GeorgoSK Sun May 23, 2010 3:36 pm
Is it possible to do all these things straight in Node inspector... ? Instead of linking in Node Graph
Intel C4Q , 4G ram, GTX 285,
GeorgoSK
Postby radiance » Sun May 23, 2010 3:42 pm
radiance Sun May 23, 2010 3:42 pm
GeorgoSK wrote:Is it possible to do all these things straight in Node inspector... ? Instead of linking in Node Graph
sure, that's how i did it, you can choose which technique fits you best.
Radiance
radiance
Postby PhilBo » Sun May 23, 2010 7:17 pm
PhilBo Sun May 23, 2010 7:17 pm
Looking great! Can't wait to play with those.
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
PhilBo
Postby MartyMart » Sun May 23, 2010 7:29 pm
MartyMart Sun May 23, 2010 7:29 pm
Hi
Don't forget to put them in the MAC build... ;)
Cheers
MartyMart
OSX 10.6.4, Imac 3.06 GHz Intel Core 2 Duo, 8 GB Memory, NVIDIA GeForce 9400
MartyMart
Postby andrian » Mon May 24, 2010 3:50 pm
andrian Mon May 24, 2010 3:50 pm
I hope you don't mind Radiance to post them here , but here they are. I have finaly some time to play with procedurals and here are the result:
last one is rendered with accidental bloom trick i discovered and rendered inside octane...
I must say that procedurals are quite fun to play with, and the results are amazing...
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
andrian
Postby radiance » Mon May 24, 2010 4:20 pm
radiance Mon May 24, 2010 4:20 pm
cool. ;)
you can make more complex ones by asigning another procedural to the 'offset' input of another procedural.
Radiance
radiance
Postby andrian » Mon May 24, 2010 5:02 pm
andrian Mon May 24, 2010 5:02 pm
Here is a simple seawater made with procedurals..
http://www.refractivesoftware.com/forum/download/file.php?id=3467&mode=view
I'll post more here if Radiance don't mind..
CGsociety gallery
My portfolio
Web site
andrian
Postby kubo » Thu May 27, 2010 12:43 am
kubo Thu May 27, 2010 12:43 am
I was too eager to test the 2.2 final, so even thou you finally didn't add the tile procedural, I could come up with this, with a little more effort they could look good.
But what I don't understand are 2 things, first why the saw wave does make that type of bump? and not one more like this http://img.archiexpo.com/images_ae/photo-g/metal-facade-cladding-aluminium-extruded-panels-73074.jpg. Also why the checkers one doesn't look like one checker up and the other one down instead of a line between them?
Also why when I add the bump map, doesn't matter the intensity of it, fireflies pop like crazy?
Hehehe, this is gonna be a lot of fun testing all the procedurals!
kubo
Postby radiance » Thu May 27, 2010 9:54 am
radiance Thu May 27, 2010 9:54 am
when using bump, you need to scale the value very much, like 0.1 or less.
Radiance
radiance
Return to Resources and Sharing
Users browsing this forum: No registered users and 15 guests
Tue Apr 23, 2024 10:20 pm [ UTC ]
cron
