Mix familial & workshop house
Forums: Mix familial & workshop house
Postby enricocerica » Sun Nov 03, 2013 7:54 pm
enricocerica Sun Nov 03, 2013 7:54 pm
Here is a revisited project of a build mixing a workshop and a familial house.
This was a nice lighting exercise especially for indoor scenes.
The main deal was to render the outdoor view with the internal furniture and to make all that fitting into the 3gb video memory, I had to export a lowres version of the furnitures.
Edit : Here are some additional information
Except the cars, everything was modeled using Blender.
All the trees and vegetation are geometry, no back plane used, instance scatters are very welcome here ;)
I used AO mode 3, AO mode 4 and pathtracing but can't point what has been rendered with what. Anyway as often I rendered two images (Sun and HDR) and mixed them.
The rendering time on two GTX580 varies from 30 min (mainly for outdoor) to 2h (for indoor) depending on the render kernel used.
I used mesh emiters in front of the windows (inside) to increase the light inside the building, portals don't bring enough light.
Postprocessing to improve lighting and contrasts as well as the tone mapping done with Photoshop and Gimp.
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
enricocerica
Re: Mix familial & workshop house
Postby Daniel Ahrens » Sun Nov 03, 2013 8:04 pm
Daniel Ahrens Sun Nov 03, 2013 8:04 pm
Amazing renders, I really like the environment! I am currently in a project where i need to make a lot of grass/trees. How did you make those with octane? Did you use any pluging to scatter the grass?
Daniel Ahrens
Postby radiant » Sun Nov 03, 2013 11:18 pm
radiant Sun Nov 03, 2013 11:18 pm
Your instancing (script) has yet again amazed me, you should look into making it available on the market, my wallet is ready :lol: :mrgreen:
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
radiant
Postby mat985 » Mon Nov 04, 2013 8:14 am
mat985 Mon Nov 04, 2013 8:14 am
Just amazing, really nice renders. Bravo!
mat985
Postby RobSteady » Mon Nov 04, 2013 8:23 am
RobSteady Mon Nov 04, 2013 8:23 am
Really great work!
To me the interiors are much better than the exteriors (many areas are almost crushed to black, too much bloom).
Interiors look beautiful though.
Can you post some details about rendertimes and kernel type?
Rob
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
RobSteady
Postby gabrielefx » Mon Nov 04, 2013 8:56 am
gabrielefx Mon Nov 04, 2013 8:56 am
oh!
fantastic!
I love the bedroom...
you used marvelous designer?
The car for me is not good for this type of building...:)
gabrielefx
Postby resmas » Mon Nov 04, 2013 11:43 am
resmas Mon Nov 04, 2013 11:43 am
Top work mate.
The interiors are just amazing 8-)
Cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
Postby RealityFox » Mon Nov 04, 2013 2:09 pm
RealityFox Mon Nov 04, 2013 2:09 pm
Nice design and render! Only thing I'm not a big fan of is all of the over exposure, It's a little distracting (although not a huge negative on the overal renders). Otherwise the render looks amazing!
RealityFox
Postby Bendbox » Mon Nov 04, 2013 2:56 pm
Bendbox Mon Nov 04, 2013 2:56 pm
GREAT Images!! I love the balance of lighting in these. I did notice that the heart bump on the white walls is wider on the close up of the vases than everywhere else (it's more compressed in all other images). Other than that these are terrific images with great attention to detail!
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Bendbox
Postby enricocerica » Mon Nov 04, 2013 6:40 pm
enricocerica Mon Nov 04, 2013 6:40 pm
Thanks to everyone,
Thanks to some of your comments I changed some outdoor images to reduce the bloom and increase luminosity in dark parts. Hope it's better ;)
I also updated the post with some additional information
@BendBox: Well seen ;) Indeed I fixed the heart bump on that image but didn't wan't to re-render all the others images, as you may guess, due to the huge time required ;)
@Gabrielefx: They were the only cars I had and corresponding more or less to utility cars ;)
@RobSteady: I updated some outdoor images.
@Radiant: I indeed use a personal version of the script but not sure it differs a lot from the one available on the site. I simply used some tricks better fitting my needs but the result should be the same. By the way I may share it but I probably should make a very light documentation. Will check that ...
@Daniel Ahrens: If you are using Blender you can use the script available in that section and indeed you'll be able to use scattering to generate instances ;)
enricocerica
Next
Return to M is for Metaverse Gallery
Users browsing this forum: No registered users and 26 guests
Thu Apr 25, 2024 12:27 pm [ UTC ]
