New 3.02 rending animation problem: it doesn't work
Forums: New 3.02 rending animation problem: it doesn't work
Re: New 3.02 rending animation problem: it doesn't work
Postby oneeyedfox » Thu Oct 04, 2012 8:26 am
oneeyedfox Thu Oct 04, 2012 8:26 am
thx matej works for me now too - blender 2.64 and plug in 1.20
oneeyedfox
Postby matej » Thu Oct 04, 2012 8:40 am
matej Thu Oct 04, 2012 8:40 am
oneeyedfox wrote:thx matej works for me now too - blender 2.64 and plug in 1.20
There might be a problem with that solution. If you abort the exporting process, then it throws some errors when you re-start again (though it seems it finishes just fine).
madcoo had some problems with corrupted blend files, so it's worth investigating if it works ok for you, before you start to use it on your production files.
cgmo.net
matej
Postby oneeyedfox » Fri Oct 05, 2012 7:45 am
oneeyedfox Fri Oct 05, 2012 7:45 am
matej I had to cancel render sequence couple times and no errors at all ,I had just one problem with textures I erased them all but slots stayed active and cause same export errors after while I find it out and fix that .here is my crapy animation test :) https://www.dropbox.com/s/6ioveijvpcfyyyl/0001-0198.avi
oneeyedfox
Previous
Return to Blender
Users browsing this forum: No registered users and 20 guests
Sat Apr 20, 2024 1:46 am [ UTC ]
