Testing Beta 0.87b (SDK 1.20) **updated 04.10**
kirbyzz
hi aoktar,
hang-up problem on render end is back...i had to use more cars and trees in my scene ..much more geometry
and now by a 2000px rendering hang up on end is back....but it saves :)
...with not so much geometry it worked...
Subroutine49690
Hello aoktar,
attention!!!
There is a problem when switching between projects while update geometry is activated. (using C4D R14)
Please Test.
Detail:
I have rendered a scene in Live-Preview with "update-geometry" activated, then I switch to another scene and simply refresh the live-preview. What happens is that the last scene that was active before is suddenly closed !! without saving !! This happens as long the update-gemotry funktion is on. If turn off and refresh different scenes, everything is fine, nothing gets closed.
Thanks again for this pretty nice update ;)
artdude12
Just tried Cinema Physical Sky and it works, sort of....
Initial render using the Octane Live Viewer is all black, then when I navigate the scene, the Live Viewer renders the scene OK.
However, if I try to render using the Picture Viewer with Octane as the chosen render, then the scene renders all black.
Am I doing something wrong?
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
artdude12 wrote:Just tried Cinema Physical Sky and it works, sort of....
no, there is no real support for that. Use sunlight or directlight instead of PS. Plugin uses Octane Daylight environment for each one.
A video for carbon scatter transparency
[vimeo]http://www.vimeo.com/75318077[/vimeo]
artdude12
OK.
RK-art
Hi Aoktar,
what about the missing Octane render settings window and the non working preview render (remains black) under R15 ?
Win 7 Ultimate 64 / 4 x Geforce GTX 590 / Intel 7 @4.00 Ghz / 24GB RAM
RK-art wrote:Hi Aoktar,
what is your r15 subversion? I can open without problem. We should wait some more for real support on R15.
buzby
Aoktar, I see 0.8.2b in your video was this released or just your copy? :) I cant get 0.82 to work without crashing, have to keep going back to 0.79
Asrock z77 extreme9 | Intel i7 3770K 3.5 | Win 7 64 bit | (1) EVGA Titan| 30" Apple Cinema Display | LEPA G1600W PSU | 16GB Ram | Storm Trooper Case |
Autodesk Inventor>3DS Max >Cinema 4D R14 Broadcast
buzby wrote:Aoktar, I see 0.8.2b in your video was this released or just your copy? :) I cant get 0.82 to work without crashing, have to keep going back to 0.79
it's very strange some people talking about crashes. But never crashes on my pc's even very complex projects. I'm really fooling with this.
What kind of crashes you say? In live viewer? With geometry updates? R14/R15? i need more details.
Also i saw you thread about phong angles. It seems like bad triangulation issues.
