Page 1 of 7
OctaneRender® for Maya® 2.25 - 7.30 Win [STABLE V2]
Posted: Wed Sep 28, 2016 6:20 am
by k.a.schubert
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 619€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® License" priced at 269€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses, just like OctaneRender™ Standalone Edition packs.
LICENSE MANAGMENT
Activating/Deactivating the plugin license can be done from within Maya® (render settings window / octane license tab).
CHANGES SINCE THE PREVIOUS VERSION
  • 1. Support added for Maya 2016.5 and 2017.
Linux and OSX versions are still under development.
DOWNLOAD
OctaneRender for Maya 2.25 - 7.30
OctaneRender for Maya 2.25 - 7.30 Demo
For network slave and daemon please download standalone installer here:
Standalone 2.25
Yours,
The OctaneRender™ Team.
Re: OctaneRender® for Maya® 2.25 - 7.30 Win [STABLE V2]
Posted: Wed Sep 28, 2016 8:39 am
by Refracty
Great!
Thank you
Is the ZDepth-Max Adjustment Problem fixed in this version?
Posted: Wed Sep 28, 2016 9:17 am
by QuinceHungaryKft
Thanks for the update!
First thing i've noticed:
It overwrites the transform nodes of images when I load a scene created before the update.
I would say this is a bug.
Posted: Wed Sep 28, 2016 1:26 pm
by ivankio
Why do you force display mode to OpenGL Legacy? It doesn't seem to improve viewport in anyway (textures still not visible in normal usage). I use DirectX for most of my shaderFX work, and well, the display mode is being called "legacy" for a reason.
Please do not make hidden changes to our Maya environment if you are reckless. Or at the very least document them. On 8.0 it was tolerable because it was alpha.
Posted: Thu Sep 29, 2016 12:47 am
by k.a.schubert
@Ivankio
Reverted that change. Download links have been updated.
@QuinceHungaryKft
The transform is not duplicated anymore.
A maya API function MPlug::isConnected() did return false, even though the MPlug was connected.
AD got a ticket for that.
@Refracty
No it is not, if the ZDepth-Max Adjustment problem would have been fixed I would have listed in >CHANGES SINCE THE PREVIOUS VERSION<.
Posted: Thu Sep 29, 2016 7:27 am
by calus
k.a.schubert wrote:@Ivankio
@QuinceHungaryKft
Thanks, it works nicely now.
Posted: Thu Sep 29, 2016 1:12 pm
by Refracty
@Refracty
When will this be fixed?
Posted: Fri Sep 30, 2016 2:05 pm
by sirenesoong
seems not working with GTX 1080... or I'making some mistakes? Thanks
Posted: Fri Sep 30, 2016 3:51 pm
by ivankio
k.a.schubert wrote:Download links have been updated.
Thank you very much for the fast fix!
sirenesoong wrote:seems not working with GTX 1080... or I'making some mistakes? Thanks
If I'm not mistaken, Octane 2 itself (standalone) doesn't support 10xx, only Octane 3 does support them.
Posted: Fri Sep 30, 2016 5:55 pm
by abeoctane
I am having a problem, because when you activate the movable proxy or resapeable proxy attribute for an object, the camera mapped texture does not work anymore, it only works when the object is in global, but I cant hide camera visibility or shadow visibílity in with a global attribute.
