How to fix Octane showing black screen?
Posted: Sun Feb 06, 2022 5:47 pm
Hello,
Sorry, I am not sure how to use the correct format here...
My octane is showing a black screen and the Log shows:
Compute error 2097152:814:
compute device 0: Linking 00696900aaaadec4 shader failed
device 0: failed to initialize render thread 0x7fdc09784250
And in the Console window it shows:
Loaded Octane DLL:Octane X Studio PR13 version:10000307 SDK:PR13
Octane X for Cinema 4D PR13 built for:250 C4D vers:25015
C4D:25015 comp:[Si’s iMac] OS:[OS X 64 BIT] macOS: 版本12.2(版号21D49) versType:10
CPU:[GenuineIntel, stepping 12, model 14, instruction family 6] speed:3.7 GHz numOfCpu:6Ht
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D R25/plugins/C4D-OctaneX-Studio-PR13/res/osl_scripts
VRAM used/free/max:0Kb/8Gb/8Gb Out-of-core used:0Kb RAM used:30.057Gb total:40Gb OpenGL free/total:0/0
File not found:/Users/sichen/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates-ox.txt
FumeFx library initialisation error!
Multi-threaded material conversion, thread count=4
Export materials time= 0.088 ms
Collect objects time= 0.027 ms
Mesh creation time = 1.852 ms.
Api update time: 0.026 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
MB:0/0 ST/MOV:0/1 Nodes:12 Tris:12 DispTris:0 Hairs:0 Meshes:1
Textures Grey8/16:0/0 Rgb32/64:0/0
>> ProcessUpdate(flags=CMOG cAsyn=1 dDelay=1
>> ProcessUpdate end res:0
>> ProcessUpdate(flags=CM cAsyn=0 dDelay=1
Does this mean I don't have enough RAM? or some file is missing in my computer? How can I fix this problem?
Thank you!
Thank you!
