bepeg4d wrote:Hi,
M1 chip support is still considered experimental at this stage, and it is still working under Rosetta 2 for plugins in Big Sur, at the moment.
Please, select the Cinema 4D.app, press Command+I, to get the Info panel, and enable the **Open using Rosetta** option:
Then install c4doctaneX PR11, that is the first version supporting c4doctaneX with M1 chip.
Note that you always need to remove from the c4doctane folder, all the unnecessary c4doctane-R2X.xdlib files not related with R2X specific version, and leave only one c4doctane-R2X.xdlib file in ../plugins/c4doctane directory.
For C4D S24, you need to keep the R23.xdlib file, and remove the other .xdlib unused files.
You also need to allow the c4doctane plugin and library in System Preferences/Security and Privacy panel, and restart C4D a couple of times.
ciao Beppe
Users browsing this forum: Majestic-12 [Bot] and 14 guests
