Particle from realflow to c4d octane
Forums: Particle from realflow to c4d octane
Postby saman » Sun Apr 16, 2017 8:14 am
saman Sun Apr 16, 2017 8:14 am
I have imported some foam particles from real flow to c4d via Real flow particle importer and i used an object tag on top of of it, but it wont show up in render?
Any help?
Saman
Win 10 64 bit | Geforce Titan X, Geforce 1060 6GB | i7 6850K |32 GB
saman
Re: Particle from realflow to c4d octane
Postby aoktar » Tue Apr 18, 2017 4:47 pm
aoktar Tue Apr 18, 2017 4:47 pm
Do you see particles tab activated in object tag? How is your object setup? Any pictures pls.
Postby saman » Fri Apr 21, 2017 11:41 am
saman Fri Apr 21, 2017 11:41 am
Actually very simple setup, just a RealFlow SD importer (which has my Real Wave Data) and RealFlow Particle importer (Which has my foam data in .bin format)
and an Object tag on top of my RF particle importer but no particle tab activated in my object tag.
And no foam shows up in my render view
saman
Postby saman » Fri Apr 21, 2017 1:47 pm
saman Fri Apr 21, 2017 1:47 pm
aoktar wrote:Do you see particles tab activated in object tag? How is your object setup? Any pictures pls.
saman
Postby aoktar » Fri Apr 21, 2017 10:03 pm
aoktar Fri Apr 21, 2017 10:03 pm
It's not a type which is supported by particle engine of plugin. Anyway you can use a way as using standard geometries.
Postby saman » Sat Apr 22, 2017 11:26 am
saman Sat Apr 22, 2017 11:26 am
aoktar wrote:It's not a type which is supported by particle engine of plugin. Anyway you can use a way as using standard geometries.
Thanks for your help dude, but I don't understand what did you mean by using standard geos. Actually
I am looking for a correct pipeline between RealFlow and C4DOctane and specially for Foam rendering on top of my RealWave Geo.
saman
Postby young.r85 » Wed Jan 24, 2018 5:56 am
young.r85 Wed Jan 24, 2018 5:56 am
Can we use rpc or bin sequences from Realflow? I don't have a particle tab when I place an Octane Object tag on my Realflow Particle Importer. Is there an existing workflow? Or are only meshes supported?
Are there work arounds for rendering Splash and Foam from particle sequences using OctaneC4D?
young.r85
Postby Sabour7 » Thu Feb 01, 2018 4:03 pm
Sabour7 Thu Feb 01, 2018 4:03 pm
Did you ever find out how to render out particles from Realflow C4D into Octane? Currently have a setup of liquid but need the particles to show a level of dirty ness to the water which the particles would help with.
Sabour7
Postby young.r85 » Thu Feb 01, 2018 7:48 pm
young.r85 Thu Feb 01, 2018 7:48 pm
Unfortunately I had to render all my splash and foam in VRay and composite onto my Octane render. It took forever since my PC is built for Octane and not VRay. I was however able to render mist using the Octane VDB Object. It would be awesome to have a full Realflow > C4D > Octane pipeline. I don't think it exists yet.
As a side note, you can mesh your core fluid in Realflow and render that in C4D/Octane.
young.r85
Postby 96rock » Mon Dec 16, 2019 2:27 am
96rock Mon Dec 16, 2019 2:27 am
Hello, Does a pipeline exist yet for this issue? I would love to render foam in Octane. RPC files
96rock
Next
Users browsing this forum: No registered users and 28 guests
Thu Apr 25, 2024 12:23 am [ UTC ]
