Spotlight issue - looks like a volume
Forums: Spotlight issue - looks like a volume
Postby PixelEyes » Wed Mar 15, 2023 1:34 am
PixelEyes Wed Mar 15, 2023 1:34 am
I'm having an issue with using the Octane Spotlight in my scene. It's creating what looks like a volume in the render and not sure how to fix or set it up to look like a light instead.
I attached a screenshot below. Any help or advice on how to properly set up the spotlight would be huge thanks!
PixelEyes
Re: Spotlight issue - looks like a volume
Postby elsksa » Wed Mar 15, 2023 12:53 pm
elsksa Wed Mar 15, 2023 12:53 pm
There will be a volume appearing if there is a volume container encompassing the scene or if a volume "spectron" light is utilized.
I've noticed the kernel settings have to be adjusted.
I'd recommend consulting three topics I wrote about:
Octane Lighting
Octane Volumes
Octane Settings
elsksa
Postby PixelEyes » Thu Mar 16, 2023 11:27 pm
PixelEyes Thu Mar 16, 2023 11:27 pm
Thanks for the response. I took a read through your site, great stuff on there! I appreciate the effort to educate you've put in.
As for the volume, the spotlight isn't encompassed by a volume container. All I did was select the Spotlight feature from Octane's Live Viewer dropdown option and, what you see in the screenshot is what shows up. It looks as if it's a volume, it might not actually be though. But it isn't light, and even when I change the values, nothing changes. I noticed you are using the standalone renderer, I'm only using the live viewer within cinema. Do you know if there is a way to edit/control the spotlight from within cinema?
Also, which kernels did you notice were adjusted? I believe I'm using what Octane provides as native values when starting up a render.
Will continue to read your site! Appreciate it.
PixelEyes
Postby bepeg4d » Fri Mar 17, 2023 7:53 am
bepeg4d Fri Mar 17, 2023 7:53 am
About Volume SpotLight in c4doctane, you are using an outdated version 2020.2.1-R3, where the Light medium node was missing from Octane Light tag:
Here is how it looks like if you upgrade c4doctane to 2021.1.7, or 2022.1-R8:
Here is the link to the manual:
https://docs.otoy.com/cinema4d/SpotLight.html
ciao,
Beppe
Postby PixelEyes » Thu Apr 27, 2023 6:56 am
PixelEyes Thu Apr 27, 2023 6:56 am
Thank you so much Beppe, that makes a lot of sense. I'm going to work on installing the new version to the new version of c4d.
Appreciate it!
PixelEyes
Postby PixelEyes » Fri Apr 28, 2023 5:58 am
PixelEyes Fri Apr 28, 2023 5:58 am
Hey Beppe,
When trying to install the new version of Octane on Cinema 2023 I was presented with this error. Attached below. Not sure how to deactivate octane in R23 and transfer it over to 2023. Thanks
PixelEyes
Postby bepeg4d » Fri Apr 28, 2023 6:17 am
bepeg4d Fri Apr 28, 2023 6:17 am
Ok, please write to help at otoy dot com sharing your OTOY username, in this way we can check your account without sharing here sensitive data.
ciao,
Beppe
Return to General Discussion
Users browsing this forum: No registered users and 30 guests
Sat Apr 20, 2024 2:19 am [ UTC ]
