VRAM Question with Multiple GPUs
Forums: VRAM Question with Multiple GPUs
Postby timot.mo » Fri Apr 23, 2021 3:18 am
timot.mo Fri Apr 23, 2021 3:18 am
I'm sure it's normal behavior, but if you have say a RTX 3090 with 24 GIGs of VRAM and you add a 1080ti for more power, is it Normal for OCTANE to use the VRAM on the smaller VRAM chipset? Being the 1080ti?
I have a 1080ti as an external GPU going through an M.2 connection and I just realized that VRAM being used is on that card and not the 3090.
I think this is correct but I just wanted to make sure.
timot.mo
Re: VRAM Question with Multiple GPUs
Postby bepeg4d » Fri Apr 23, 2021 6:29 am
bepeg4d Fri Apr 23, 2021 6:29 am
Yes correct, since the scene must be loaded completely in each GPU, the active GPU with less VRAM defines the limit of the system.
ciao Beppe
Postby timot.mo » Fri Apr 23, 2021 2:42 pm
timot.mo Fri Apr 23, 2021 2:42 pm
Thank you! I don't know why I forgot that. Probably because it's the first time I've had mismatched GPU's. ;)
timot.mo
Return to General Discussion
Users browsing this forum: No registered users and 41 guests
Thu Apr 25, 2024 5:31 am [ UTC ]
