OBJ importing too many materials.
Forums: OBJ importing too many materials.
Postby Renart » Sat May 12, 2018 11:07 pm
Renart Sat May 12, 2018 11:07 pm
Hello!
Quick question!
In Maya or Blender, I have 2 separate cubes, one with a red material, one with a blue material.
If I export the red cube only and import it in Octane, there will be 2 material inputs, one red and one blue.
But if I re-import the same obj to Maya or another software, the blue material is not showing. So it's only a Octane thing.
It's very problematic when I have a huge scene and I want to export only one small object. All the others materials of the scene will also be imported, creating a very long node full of useless inputs in Octane.
What would be the best solution to avoid that?
Please do not say I should use other formats, I'm just asking about obj here :)
Thanks!
Renart
Re: OBJ importing too many materials.
Postby Phantom107 » Sun May 13, 2018 9:34 am
Phantom107 Sun May 13, 2018 9:34 am
Octane only deals with the data it's given. It s possible the exporter is including materials in the MTL that are not present in the OBJ's geometry (reference: https://en.wikipedia.org/wiki/Wavefront_.obj_file). Try simply deleting the MTL file and then import the OBJ in Octane.
Phantom107
Postby Renart » Mon May 14, 2018 4:09 am
Renart Mon May 14, 2018 4:09 am
Thanks! It works.
I'm wondering if there is a way for Octane to avoid reading useless information like this from the files..
But it's a good work around, thanks.
Renart
Postby Zay » Mon May 14, 2018 1:06 pm
Zay Mon May 14, 2018 1:06 pm
Hide/remove what you don't need before you export. I do it all the time in Modo and Poser.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 546.01| Modo/Blender/ZBrush/Daz/Poser
Zay
Postby m0th » Thu Oct 18, 2018 7:18 am
m0th Thu Oct 18, 2018 7:18 am
I'm running into this as well in 3.08.3 Standalone when exporting an .obj from Maya.
I've tried deleting the unnecessary materials from the .mtl text file.
Tried deleting the entire .mtl file
Tried deleting all of the extraneous materials in my Maya scene
Tried exporting with materials unchecked
Tried exporting with just face sets
None of which worked for me.
I have come across something odd. If I export the obj with all options set to off, no Groups, no Point Groups, no Materials, no Smoothing, no Normals and overwrite or leave the name exactly the same as the original obj with unnecessary materials, it still exports with all of the unneeded materials, or the .mtl file isn't being overwritten.
Now, if I change the file name to something like test.obj on export with all of the same options listed above, the obj will import into Octane with only one input (none of my materials). If I turn materials on during export and overwrite the same file (test.obj), still only one input... it's just called Diffuse Material.
Next, I exported another obj called test2.obj with only Materials enabled during export. All of the materials including the unnecessary materials show up again in Octane.
Finally I deleted all of the extra materials in my Maya scene and called the obj test3.obj. It then imported with the correct materials, kind of. It still brought in the initialShading group node, which Maya won't let me delete.
Needless to say, this is far from an ideal workflow.
I've only recently started using octane over the past few months and I was hoping this was just an isolated incident or two, but it's starting to do my head in. I've kind of just been putting up with it, chalking it up to lack of experience with the software. Alternately I've tried alembic, but Maya won't let me overwrite the .abc file while it's open in Octane. I'm also getting weird scale issues with Alembic, even with World Space option on during export. Obj is usually the tried and true method, so it would be nice to get that working smoothly.
I hope that makes sense. Any help would be much appreciated. Thanks!
Windows 10 | GTX 1080Ti | AMD Ryzen 1950x |64GB Ram
m0th
Return to General Discussion
Who is online
Users browsing this forum: No registered users and 41 guests
Thu Apr 25, 2024 11:21 am [ UTC ]
