colekush wrote:Nice looking build rappet, great work!
If I was using Octane network rendering and the budget was available, would you say it would be more ideal to have 2 rigs similar to the build you made with 3-4x 1080ti's in each, or a single 7x 1080ti rig similar to the builds of Tom Glimps or smicha?
I would assume 2 rigs could have more costs with the extra license and componentry, but if there is a tight schedule on a project would it be safer to have 2 rigs running in case one might have issues? Or are there any other things to consider?
The difference of one extra license is neglectable I think... when the price is not more difference the couple hundred dollars/euros the I would prefer building two gpu rigs (with 7 gpu) instead of one rig (with 7 gpu).. easier in future to adjust config, and also having backup just in case.
When using the rigs only for networkrendering as slaves, and not as a pc to work on projects or use for other purpose then just slaves.. then you could build 1 or 2 rigs with less specs.. less ram, less cpu.. building two rigs with 4 gpu and less specs might be chepaer then building one rig with 7 gpu and more specs.
I build mine as a renderslave, but also as a second working station, therefor I have chosen higher specs then if I would build a renderslave only.
i.e. I had build a renderslave once by using an old PC that I was not using anymore with old mobo few ram and less cpu then these newer ones, and stuffed it with new gpu's.
You have to make sure you enough pci lanes to run the number of gpu ofcourse.
I think you have to do some math by comparing the configs you need,
after first making choice building working pC or slaves.
Maybe then building one 11 gpu rig (like Smicha is doing) might be the relative cheap way to go.. I do not know.
Ofcourse it can be much more convenient having 'just one'slave instaed of 3.. you have to monitor more PC's..
I did not go that route though.
That is my two cents.
greetz,
edited/added: Oh, and having at least one slave on air and not on water has benefit of swapping newer GPU in few years easily.. I have done that a few times now.. going from 580 to 780 to 1080... On water has benefit of lower temps on card and you might be able to stick more cards in one config... but just a thought to makae you think about future plans as well
