mix 3 material
Forums: mix 3 material
mix 3 material
Postby Matteo3d » Tue Aug 08, 2017 1:35 pm
Matteo3d Tue Aug 08, 2017 1:35 pm
Hello guys,
I would like to create an effect on a geometry,
A statue, I would like from the feet to the thighs to be water (material), from thighs to chest, from wood, from chest to head, in fading together,
I've tried with mix material and a gradient structure, it works but I have only two possibilities of materials,
Do you have a solution?
Thank you
win 10, 64 gb, 2x 1080ti
Matteo3d
Re: mix 3 material
Postby FrankPooleFloating » Tue Aug 08, 2017 2:05 pm
FrankPooleFloating Tue Aug 08, 2017 2:05 pm
Hmmm... Maybe build it as mat1 to mat2 as one mix, and mat2 to mat3 as another, then mix those two mixes?...
FrankPooleFloating
Re: mix 3 material
Postby itsallgoode9 » Tue Aug 08, 2017 3:25 pm
itsallgoode9 Tue Aug 08, 2017 3:25 pm
Matteo3d wrote:Hello guys,
Thank you
You have to pipe the first mix material into another mix material to mix more than two materials together. There's no layering with alphas, like Maxwell Render or Photoshop.
It's the most damn convoluted and sloppy system possible, but devs don't seem to care. It's been brought up multiple times in the past and the issue gets ignored.
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
Re: mix 3 material
Postby bepeg4d » Wed Aug 09, 2017 7:31 am
bepeg4d Wed Aug 09, 2017 7:31 am
Hi guys,
in my opinion is not the damn convoluted and sloppy system possible... you have a lot of flexibility, and possibilities.
Here is a fast example of a Mix of a Mix of a Mix with four different materials:
MixMixMix.orbx
(948.55 KiB) Downloaded 122 times
ciao beppe
Re: mix 3 material
Postby itsallgoode9 » Wed Aug 09, 2017 10:09 am
itsallgoode9 Wed Aug 09, 2017 10:09 am
Imagine working in Photoshop if you could only make 2 layers interact at a time...
Basic stuff like you're showing is not a problem, but it gets messy and hard to read with complicated materials. The 2 material mix material setup as a the default way to combine materials adds zero benefit over a layered system, it only needlessly complicates graph nodes; there is nothing in your graph node that couldn't be achieved in a layered setup, all the while, reducing two of your mix material nodes, effectively cutting your node graph in half.
The first image I attached shows one of my material graphs for a project at work. All the nodes circled in red are mix nodes piped into other mix nodes. The second image shows how the same material would be laid out if it were a layered material approach. In the layered setup, it can clearly be seen that there are 5 of materials. If another artist were to work on my project, they could see that immediately , without needing to decipher anything . With the mix material setup, there is no way to figure out exactly what is going on without tracing your through the entire graph from the topmost node.
A layered approach reduces nodes needed AND keeps all of your material nodes in the same space visually, making it easier to read.
itsallgoode9
Re: mix 3 material
Postby Matteo3d » Wed Aug 09, 2017 11:33 am
Matteo3d Wed Aug 09, 2017 11:33 am
ciao Beppe, wow, fantastic
Matteo3d
Re: mix 3 material
Postby Matteo3d » Fri Aug 11, 2017 7:16 am
Matteo3d Fri Aug 11, 2017 7:16 am
Hello guys,
I solved with Beppe's solution,
Very kind, helped me and created the perfect mix material! 8-)
Matteo3d
Return to General Discussion
Users browsing this forum: No registered users and 13 guests
Tue Apr 23, 2024 9:56 pm [ UTC ]
