World Creator 3
Forums: World Creator 3
Re: World Creator 3
Postby mikefix » Fri Jun 03, 2022 1:40 am
mikefix Fri Jun 03, 2022 1:40 am
Also waiting on Lightstage.
mikefix
Re: World Creator 3
Postby Singular1974 » Tue Jun 07, 2022 3:34 pm
Singular1974 Tue Jun 07, 2022 3:34 pm
Literally been waiting half a year.
Singular1974
Re: World Creator 3
Postby HandcraftedMedia » Thu Jun 09, 2022 10:10 pm
HandcraftedMedia Thu Jun 09, 2022 10:10 pm
Any updates?
HandcraftedMedia
Re: World Creator 3
Postby Vector6 » Wed Jun 15, 2022 2:18 am
Vector6 Wed Jun 15, 2022 2:18 am
I would also like to know.
I subscribed to World creator directly and just discovered I had been billed twice 3 times.
Waiting on their response Atm. But it's a kick in the balls when it should be included here by now.
Aaron
Vector6
Re: World Creator 3
Postby Turck » Tue Jun 21, 2022 1:23 pm
Turck Tue Jun 21, 2022 1:23 pm
Wait, I just subscribed to 1 year Enterprise+ and you tell me that we don´t have access to the latest World Creator edition?
And what about Lightstage? In the description it said s.th. about access to the 3D scans.
Turck
Re: World Creator 3
Postby Terryvfx » Sat Jun 25, 2022 6:20 pm
Terryvfx Sat Jun 25, 2022 6:20 pm
Any news about when or if we are getting the lastest version of WC3?
Terryvfx
Re: World Creator 3
Postby dynaraton » Wed Jul 06, 2022 1:37 am
dynaraton Wed Jul 06, 2022 1:37 am
FYI, World Creator 2022.2 for Octane is available. Thanks Otoy!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win10 Pro : Latest Cinema4D
dynaraton
Re: World Creator 3
Postby MyRho » Wed Jul 06, 2022 6:17 pm
MyRho Wed Jul 06, 2022 6:17 pm
Yes - thank you.
Unfortuantely it's crashed and it won't start again. :(
Intel Core i7 3960X, X79A-GD65 (8D) (MS-7760), 32 GB DDR3-SDRAM G.Skill,
Asus GeForce GTX 3060 12GB, Windows 10 Pro 64-Bit.
Nihil sum sine sole.
MyRho
Re: World Creator 3
Postby GXGsynth » Sun Jul 31, 2022 7:13 pm
GXGsynth Sun Jul 31, 2022 7:13 pm
why is World Creator 3 not available except for those who purchased on Black Friday, despite the main OTOY site promising:
all paid Octane subscription tiers starting at just 13.95 €/month (with Black Friday discount), including annual passes to: Greyscalegorilla Plus, LightStage MetaFace scans – a preselected free kit from KitBash3D every month – and full commercial licenses to World Creator, EmberGenFX, Architron, and Sculptron.
Embergen works, Sculptron works, Architron works, the Kitbash3D codes work, yet there's a "not licensed" error when opening the normal version of World Creator 2022? (GreyscaleGorilla plus doesn't work either, I dug through the fine print and found that it's only "annual" subscribers that get access, and even then only people who signed up last year, I emailed them and got no response)
World Creator for Octane basically broken, it doesn't export screenshots at all, and needs to be told what folders to export to every time the program is opened, the rotate functionality doesn't pivot around anything in particular, etc.
even then, the only thing I can get it to export is an orbx file with a greyscale exr displacement map attached to a plane and an extremely convoluted setup of an RGB image -> multiply texture -> diffuse material layer -> diffuse material, which contains no roughness/spec/normal/or any other texture file, so even water is just a blue diffuse surface, despite "IncludeMaterials" being set to ON.
neither image can be used outside of the orbx file, unless there's a way I'm unfamiliar with of extracting files from within an orbx container. so for all the awesome capability World Creator seems to have from the demos I've seen, it's rather useless in terms of actual functionality in the Octane version...
GXGsynth
Re: World Creator 3
Postby bepeg4d » Mon Aug 01, 2022 6:33 am
bepeg4d Mon Aug 01, 2022 6:33 am
you can open the WC3 .orbx in Standalone, and use the Unpack package command, to obtain an Assets folder with all the maps:
ciao,
Beppe
PreviousNext
Return to General Discussion
Users browsing this forum: Bing [Bot] and 31 guests
Thu Apr 25, 2024 9:53 am [ UTC ]
