Octane leaf material
Forums: Octane leaf material
Postby DanCaldwell3D » Mon Dec 16, 2019 1:56 am
DanCaldwell3D Mon Dec 16, 2019 1:56 am
Hi all,
I'm trying to create an Octane leaf material and having some difficulty.
Currently I'm using a Universal material, with the diffuse map connected to both Albedo and Transmission, with a color correction node between the map and Transmission to control hue, strength etc. which works okayy..
The trouble is, if the leaves are curved or on an angle the translucency effect is kind of dark, and the overall feel when light shines through is more like stained glass rather than a translucent leaf.
Just wondering what the best way to set this up is. Other renderers such as V-Ray have a setting specifically for this scenario ie. translucency on single sided geometry, but Octane seems to not have this kind of function.
Grateful for any help on this, thanks :)
DanCaldwell3D
Re: Octane leaf material
Postby bepeg4d » Mon Dec 16, 2019 9:50 am
bepeg4d Mon Dec 16, 2019 9:50 am
Which version are you using?
In latest 2019.1, and 2020, there is a Transmission Type popup, that can be set to Diffuse:
ciao Beppe
Postby DanCaldwell3D » Tue Dec 17, 2019 1:48 am
DanCaldwell3D Tue Dec 17, 2019 1:48 am
Thank you so much Beppe, exactly what I was looking for!
Cheers
DanCaldwell3D
Postby Dingbat » Wed Jan 26, 2022 9:12 am
Dingbat Wed Jan 26, 2022 9:12 am
i've tried several ways to do this but they all have the same result - as soon as i make the leaf translucent any specular is lost
i've tried the layered material (Diffuse main + Specular layer, and Glossy main plus Diffuse layer), and the examples below use the Universal material
i've also tried adding a Coating and/or Sheen instead of Specular but very little difference
1st example is with a texture used for translucency
in the 2nd example - with just a value instead of texture - even with only 0.01 translucency the specular disappears
what am i missing?
Octane 2021.1.1
MODO plugin, but also tried in standalone and same result
Dingbat
Postby john_otoy » Thu Jan 27, 2022 2:23 am
john_otoy Thu Jan 27, 2022 2:23 am
Dingbat, can you try disabling kernel > nested dielectrics?
Wallace replied to a related issue here: viewtopic.php?f=23&t=78819&p=407037#p407037
john_otoy
Postby Dingbat » Thu Jan 27, 2022 9:12 am
Dingbat Thu Jan 27, 2022 9:12 am
no change
i've attached the scene with only a diffuse colour and 0.01 transmission
if you change transmission to 0 the specular will appear as expected
Nested Dielectrics is unchecked
Transmission_01.orbx
(123.12 KiB) Downloaded 102 times
Dingbat
Postby SSmolak » Thu Jan 27, 2022 1:24 pm
SSmolak Thu Jan 27, 2022 1:24 pm
Strange. It looks like bug. Too bad because I'm going to vegetaion heavy scene.
SSmolak
Postby SSmolak » Fri Jan 28, 2022 1:49 am
SSmolak Fri Jan 28, 2022 1:49 am
What about this ? Should works fine now. You didn't have any Dielectric/IOR map. Also you can add a little metallic effect.
Transmission_02.orbx
(124.39 KiB) Downloaded 109 times
SSmolak
Postby john_otoy » Fri Jan 28, 2022 4:04 am
john_otoy Fri Jan 28, 2022 4:04 am
Dingbat wrote:no change
Thanks for the scene. We'll look into it
john_otoy
Postby SSmolak » Fri Jan 28, 2022 9:41 am
SSmolak Fri Jan 28, 2022 9:41 am
It looks like Transmission overrides Specular Roughness. When Transmission is ON even a little it switch to its own Roughness parameter that is much lower than Specular Roughness.
SSmolak
Next
Return to General Discussion
Fri Apr 19, 2024 6:23 pm [ UTC ]
