whersmy wrote:Well basically you should always work in real-life metrics.
I don`t think you have to adjust the scale of the scene. It`s just a matter of scaling the map on the object in your scene.
whersmy wrote:Good question. I think if you just model/compose the scene in real-life metrics and export as .obj, Octane loads it in nicely. You might want to edit the import optins (from M to mm).
bepeg4d wrote:Hi,
everything in Standalone is in meters, so if you use the Box projection, you can correctly scale your map, based on real life measures.
ciao Beppe
Users browsing this forum: No registered users and 18 guests
