Should I change my motherboard? Or how to stay sane.
Forums: Should I change my motherboard? Or how to stay sane.
Re: Should I change my motherboard? Or how to stay sane.
Postby glimpse » Thu Apr 26, 2018 3:25 pm
glimpse Thu Apr 26, 2018 3:25 pm
Hi, Guys,
quick note on this topic. From what we managed to find with other guys on our Facebook group & other parts of web that this seems to be an issue with PLX equipped boards. Nvidia was contacted multiple times & is aware of this issue. SomeOne wrote on tomsHardware that nvidia was able to replicate this crash and is working on solving this.
For now, solutions would be:
* stick with older drivers & older OctaneRender version if You have some ongoing projects to finish,
* downgrade to w7 - seems some guys are able to get x99e ws working there without any issues with newer drivers & new build of OctaneREnder,
* try linux - again, for some it works,
in the end, hopefully solution is going to come from nvidia & these boards will be as stable as they were before.
tomGlimps | [email protected] | 32GB | TitanBlack
Available for Freelance, Coaching & Mentoring
glimpse
Postby nautical007 » Fri Apr 27, 2018 7:08 pm
nautical007 Fri Apr 27, 2018 7:08 pm
Thank you Tom for the latest info and all the help you provide on these forums (both here and Facebook).
nautical007
Postby coilbook » Mon Apr 30, 2018 3:43 am
coilbook Mon Apr 30, 2018 3:43 am
Hi i just built a salve system with asus X99-E-10G WS it has 3 video cards with netstor turbox attached total 7. When I send over a scene to render I get PC just rebooting with the crash or just completely freezing. is this basically the same problem you are having? I do have window 10 and I am afraid windows 7 wont even recognize 7 GPus Not sure what to do :(
There is also 6 pin connector that I never connected. Not sure what it is for. My evga 1600 does not even have this kind of cable.
i tried 382. drivers and i cannot even use them with because octane 3.08 says cuda driver version is too low.
coilbook
Postby itou31 » Mon Apr 30, 2018 12:42 pm
itou31 Mon Apr 30, 2018 12:42 pm
This connector helps power for PCIe, I think that you should connect it to the power supply. Be carefull, chek the polarity. On my board, I've connected all power connector (Xeon overclocking and 7 GPUs)
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
itou31
Postby coilbook » Mon Apr 30, 2018 1:05 pm
coilbook Mon Apr 30, 2018 1:05 pm
itou31 wrote:This connector helps power for PCIe, I think that you should connect it to the power supply. Be carefull, chek the polarity. On my board, I've connected all power connector (Xeon overclocking and 7 GPUs)
can this also be the reason PC freezes as soon as octane starts rendering? And do i run a wire from VGA port or peripherals? Thank you
UPDATE: it works fine with drivers mentioned in the above post 382 and octane 3.06 so it is PLX bug. Returning the motherboard I guess who know when they will fix the bug.
coilbook
Postby linvanchene » Mon Apr 30, 2018 3:05 pm
linvanchene Mon Apr 30, 2018 3:05 pm
This may not apply to the watchdog violation error of the original poster but may help some others:
My Watchdog DPC violation was triggered by high temperatures. The display GPU with 3 fans was blowing hot air at the rendering GPU installed below.
Updated / Edited - rephrased
What may have been the issue for my system may not be an issue with other builds and other variations of the Watchdog DPC violation.
I used one Asus GTX 1080 STRIX A8G for the display in the top PCI slot.
Below that the two Asus GTX 1080 Ti FE were sloted.
When I used whocrashed the error information told me that my specific Watchdog DPC violation error code could also be triggered by overheating.
http://www.resplendence.com/whocrashed
I switched the two Asus GTX 1080 Ti FE to the top two PCI express slots and assigned the Asus GTX 1080 STRIX A8G to the bottom one.
From that point on forward the watchdog DPC violation errors were gone for me.
My assumption was that the three fans of the Asus GTX 1080 STRIX A8G were blowing hot air directly at the Asus GTX 1080 Ti FE.
This seemed to have triggered the Watchdog DPC Violation after some GPU running time for me.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
Postby glimpse » Mon Apr 30, 2018 3:17 pm
glimpse Mon Apr 30, 2018 3:17 pm
linvanchene wrote:This may not apply to the watchdog violation error of the original poster but may help some others:
I've built multiple systems in the past (4-7 GPUs) & some of them were spitting this error under wrong drivers. Some of them have overkill radiators that keep all GPUs below 50C - this error has nothing to do with temperature if I would have to guess..
glimpse
Postby nautical007 » Mon Apr 30, 2018 5:18 pm
nautical007 Mon Apr 30, 2018 5:18 pm
Yes, I can also confirm that this is not a heat issue. My cards are hybrid and hardly ever get hotter than 45 degrees even under full load. Also, the watchdog errors are not just during rendering, even scene loading could cause problems.
I think as others are saying PLX chip on Windows 10 with post Nvidia 382 drivers is the fatal combination. Hopefully Nvidia can fix that.
nautical007
Postby FAZ » Wed May 16, 2018 1:35 pm
FAZ Wed May 16, 2018 1:35 pm
itou31 wrote:Have only problem when I've played with vbios. Now revert back to original vbios to pass the cuda 9.10 drivers (from 387.92).
Hello,
Could you elaborate more on this? I am having the same problem as the op. Going nuts myself here.
www.alexdimella.com IG @alexdimella
FAZ
Postby itou31 » Wed May 16, 2018 7:42 pm
itou31 Wed May 16, 2018 7:42 pm
Hi FAZ,
I have overclocked a lot my GPUs, and unlocked some power limits by flashing custom GPUs BIOS (Vbios) years ago, and completly forget this until updating nvidia drivers to the first one that include CUDA 9.10 -> direct windows BSOD, or cannot install drivers at all, until I read somewhere that new drivers should be modified to accept power limit modification. Now I have no time anymore to overclock so I revert back all my GPUs to original Vbios.
Also on my 7GPUs rig, I have one 980Ti that refused to install drivers (this 980Ti is not vbios modified by me), so I've checked the model and manufacturer and found the original bios and flashed it : can now install drivers (387.92 and up) again.
itou31
PreviousNext
Return to General Discussion
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
Thu Mar 21, 2019 12:01 pm [ UTC ]
