"Time Limit(sec)" should override "Max. samples"
Posted:
Mon Nov 14, 2016 12:21 pm
by moebius
Titel says it all.
Re: "Time Limit(sec)" should override "Max. samples"
Posted:
Tue Dec 20, 2016 9:48 pm
by Tag12345
Agreed. I find that no matter what, the time limit isnt accurate and is mostly off by some 30 seconds due to the sample limit
Posted:
Fri Mar 15, 2024 8:13 am
by moebius
Wouldn't that make sense? for previews I often render 124 Samples. But it should be easy to implement an infinite sample rate when, I change the seconds above 0?
thanks aoktar for replay
Posted:
Fri Mar 15, 2024 11:56 am
by aoktar
Hello, not sure what you are asking!!!
Time limit is working as I supposed that works. What's the problem or question? Give more solid info to let me understand it!
Posted:
Fri Mar 15, 2024 12:39 pm
by moebius
When I set a "Time Limit" Octane renders for that time (eG 5 min). Thats fine. BUT: If "max samples" are low, for eG 124 samples, octane stops rendering at 124 samples. Does not render for 5 min
I have first set the samples verry high, so that octane renders for the "Time Limit" i was giving it.
sorry if i wasn't that clear
Posted:
Fri Mar 15, 2024 1:30 pm
by aoktar
moebius wrote:When I set a "Time Limit" Octane renders for that time (eG 5 min). Thats fine. BUT: If "max samples" are low, for eG 124 samples, octane stops rendering at 124 samples. Does not render for 5 min
Yes you have to do it for now, not hard I believe. Somethings may look easy from outside but not internally sometimes. Just noted your request...
Posted:
Fri Mar 15, 2024 1:59 pm
by moebius
thanks
no it's not hard.
keep on doing more important stuff
