Octane Scatter texture map
Forums: Octane Scatter texture map
Sub forum for help and tutorials.
Moderator: aoktar
Postby Pymenvert » Mon Nov 20, 2017 1:21 pm
Pymenvert Mon Nov 20, 2017 1:21 pm
Hello,
I try to project texture from an image on an Octane Scatter. I tried using several techniques but it does not work. The best result was obtained with Image Texture and Triplanar but I still can not get my texture in place.
Could you tell me what to do?
Do you know any intelligence resources about this?
Thanks for your help
Pymenvert
Re: Octane Scatter texture map
Postby bepeg4d » Mon Nov 20, 2017 6:09 pm
bepeg4d Mon Nov 20, 2017 6:09 pm
Hi Pymenvert,
sorry for the terrible example:
instanceidtexture.zip
(2.49 MiB) Downloaded 523 times
ciao beppe
Postby Pymenvert » Wed Nov 22, 2017 9:50 am
Pymenvert Wed Nov 22, 2017 9:50 am
Hello Bepeg4g
Ok i need an object shader !
Thank you for your help !!!
Pymenvert
Postby dinf » Mon May 28, 2018 5:17 pm
dinf Mon May 28, 2018 5:17 pm
Hey, thanks for this!
@bepeg, Ahmet - is this the only way to get a colored map onto the scattered objects? It is a working workaround, but sooo slooow :'/ (v4 XB2.1)
Hair is much faster in this special cases, also randomized color, but colormap as source would be best. Is there another, probably faster possibility in sight?
ThX!
| Win 10 | 64 GB RAM | AMD 5900X | RTX 3080 12 GB| C4D 21| C4Doctane v2022.1.1|
dinf
Postby aoktar » Mon May 28, 2018 5:31 pm
aoktar Mon May 28, 2018 5:31 pm
How many instances do you have? And are they engage each others?
Please define what's slow? Rendering or somethings else?
Check this page: http://www.aoktar.com/octane/InstanceColor.html
Postby dinf » Mon May 28, 2018 9:28 pm
dinf Mon May 28, 2018 9:28 pm
aoktar wrote:How many instances do you have? And are they engage each others?
Hair will take 10 sec. preparig before I can see the first rendering with map based colored ... strands? in viewport. 100.000 Hairs with 3 segments, krinkeled and knitted cones (don't know the exact english words).
That is fast to my machine for hair, but slow compared to your pure scattering object. scattering based on a b/w map, cones with 3 hight segment and 6 arround - but in white ^^
Now, compared to bepeg's method with InstanceColor node plus texture effector and based on particles scattering, this takes 30 secods and more to prepare and start rendering. But it is hard to compare, since I scatter the cones via b/w-map in scatter-object scale slot - so I have to use about 5 times more clones and more toget a similar effect. Probably thats the problem? May I send you the file if you have time for an eye on it?
And also viewport is very slow with this method. rendering itself is normally-fast.
dinf
Return to Help / Tutorials
Wed Apr 24, 2024 12:12 am [ UTC ]
