VisibleBackground c4d Xpresso
Forums: VisibleBackground c4d Xpresso
Sub forum for help and tutorials.
Moderator: aoktar
Re: VisibleBackground c4d Xpresso
Postby cendrick » Sat Jun 16, 2018 6:27 pm
cendrick Sat Jun 16, 2018 6:27 pm
This is fantastic,
Quick question...the background image looks amazing. How can I now make it an image sequence so I can put in a video for example?
Rick
cendrick
Postby Jamma » Wed Jan 16, 2019 7:08 pm
Jamma Wed Jan 16, 2019 7:08 pm
Hey guys is it possible to make the background a movie?
Jamma
Postby TonyBoy » Wed Jan 16, 2019 9:38 pm
TonyBoy Wed Jan 16, 2019 9:38 pm
Make it a material on a panel that you can create an image sequence as long as you like using C4D animation.
TonyBoy
Postby Jamma » Thu Jan 17, 2019 11:56 am
Jamma Thu Jan 17, 2019 11:56 am
cool thanks for the help :)
Jamma
Postby GIOLETS » Fri Oct 25, 2019 1:54 pm
GIOLETS Fri Oct 25, 2019 1:54 pm
Hi Beppe! How are you?
I use this useful script quite every day and is really a must!
I ask if is possible to solve in some way (perhaps my fault) the situation when you can't have a Camera not tilted because in this case the background image don't fit the screen.
There is a simple workaround?
Thanks again for your help.
Luca
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
GIOLETS
Postby bepeg4d » Fri Nov 08, 2019 11:24 am
bepeg4d Fri Nov 08, 2019 11:24 am
Ciao Luca,
everything seems to work as expected here with X, Y, Z camera rotation :roll:
ciao Beppe
Postby GIOLETS » Wed Nov 13, 2019 11:08 am
GIOLETS Wed Nov 13, 2019 11:08 am
Hi dear Beppe!! How are you??
Please check if you see the problem rotating the camera angle "P" to +5° (positive).
Thanks again.
Luca
GIOLETS
Postby AndrewStrasser » Mon Feb 08, 2021 11:31 pm
AndrewStrasser Mon Feb 08, 2021 11:31 pm
Dear Octane Developers!
You guys are awesome!!! Thank you for all the hard work!
I was wondering if it would be possible to add this functionality direclty into the plugin so that it is not some kind of an xpresso work around?
Thank you! Redshift has a very clear way of adding a background, so Octane should as well!!!
Big Bless,Andrew
AndrewStrasser
Postby muchogrande » Thu Feb 25, 2021 7:13 pm
muchogrande Thu Feb 25, 2021 7:13 pm
Thank you for this Beppe! It's great, but I am having the same issue as Luca. The plane is not following P rotation (H and B work as expected).
muchogrande
Postby bepeg4d » Fri Feb 26, 2021 10:13 am
bepeg4d Fri Feb 26, 2021 10:13 am
Sorry, so many things, and it is a long time that I don’t check this, but I think we have solved with Luca by using the following cameraMap_environment.osl script by Calus:
viewtopic.php?f=21&t=65575
Please Luca, help me remember this :D
ciao Beppe
PreviousNext
Return to Help / Tutorials
Tue Apr 23, 2024 11:38 pm [ UTC ]
