Re: ==== Octane useful scripts ====
Posted: Wed Aug 23, 2023 11:42 am
SSmolak wrote:Is there way to change compression only for textures that have "diffuse" in their name for example ? Unfortunately change compression globally for selected textures in Octane Texture Manager is not possible for many of them selected - it ask for every texture.
- Code: Select all
import c4d
ID_OCTANE_IMAGE_TEXTURE = 1029508
def collect(shdList, n):
if n is None:
return
if n.GetType() == ID_OCTANE_IMAGE_TEXTURE:
ix =- 1
try:
ix = shdList.index(n)
except:
ix = -1
if ix == -1:
shdList.append(n)
if n.GetDown():
collect(shdList, n.GetDown())
if n.GetNext():
collect(shdList, n.GetNext())
def main():
doc = c4d.documents.GetActiveDocument()
matList = doc.GetMaterials()
for mat in matList:
shaders = []
collect(shaders, mat.GetFirstShader())
for shader in shaders:
if 'diffuse' in shader[c4d.IMAGETEXTURE_FILE].lower():
shader[c4d.IMAGETEX_COMPR_FORMAT] = 0
if __name__ == '__main__':
main()
Here you go!
This line is where you choose the parameter, you can use trial and error
- Code: Select all
