Displacement + bump trick
Forums: Displacement + bump trick
Sub forum for help and tutorials.
Moderator: aoktar
Re: Displacement + bump trick
Postby whersmy » Sun Jun 21, 2015 12:03 pm
whersmy Sun Jun 21, 2015 12:03 pm
:o
Octane 2022.1.1 nv535.98
mac pro g5| pentium g2030 iGPU| maximus extreme V| 2x gtx590 - 8gb - SSD - win7-x64- 1500W Silverstone|
x201t - gtx580 - egpu ec
Octane Render experiments
whersmy
Postby linvanchene » Tue Jun 23, 2015 2:07 pm
linvanchene Tue Jun 23, 2015 2:07 pm
Awesome discovery. :D
Thank you very much for sharing!
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
linvanchene
Postby Raoul » Thu Jul 02, 2015 2:48 am
Raoul Thu Jul 02, 2015 2:48 am
Hmm.. This doesn't seem to be working for me. I seem to get a lot of artefacts when used on more complex surface. Like a hand for example.
I'm using the mix material as suggested. It looks fine when placed on a simple cube but on more complex geometry it seems to start to get funky.
Any thoughts on a workaround and is this an issue likely to be fixed in the 3.0 update?
Thanks all.
R
Raoul
Postby Lewis » Thu Jul 02, 2015 6:02 am
Lewis Thu Jul 02, 2015 6:02 am
Hmm, for me it works without material Mixer node also. I tried (it's loose node on right bottom) both (with and without mixer node) and it looks exactly same. You even can plug in just one input for material mixer and leave amount at 0 ot 100% (depending which one you plugged) in and it still works, But this way it's one node less, or I'm missing something ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Lewis
Postby gordonrobb » Thu Jul 02, 2015 8:21 am
gordonrobb Thu Jul 02, 2015 8:21 am
In your example Lewis, are you certain (sorry to ask stupid question) that the bump is contributing. Does it look different with/without the bump input?
gordonrobb
Postby Lewis » Thu Jul 02, 2015 8:38 am
Lewis Thu Jul 02, 2015 8:38 am
gordonrobb wrote:In your example Lewis, are you certain (sorry to ask stupid question) that the bump is contributing. Does it look different with/without the bump input?
Yes, those small noisy bumps are from noise procedural. If I disconnect bump then i get smooth sides of mountains/rocks.
Check the difference (sorry for watermark I've not activated license here at work machine since i have only GTX 660 so i don't really use it at work anyway so this is on Octane 2.16 demo in this example ;))
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Postby gordonrobb » Thu Jul 02, 2015 1:36 pm
gordonrobb Thu Jul 02, 2015 1:36 pm
Hhm, Now see that confirms what I thought, that bump and displacement 'do' work. Why are folks saying it doesn't work?
gordonrobb
Postby bepeg4d » Sat Jul 04, 2015 7:51 am
bepeg4d Sat Jul 04, 2015 7:51 am
hi Lewis,
what happen if you use a normal map with displacement?
ciao beppe
Postby Lewis » Sun Jul 05, 2015 9:55 am
Lewis Sun Jul 05, 2015 9:55 am
bepeg4d wrote:hi Lewis,
ciao beppe
Hmm, good point, I've not tried/tested that but then agian why woud you need displacement and normal map in same time when normal map is just "faking" displacement effect ?
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Postby gordonrobb » Sun Jul 05, 2015 10:17 am
gordonrobb Sun Jul 05, 2015 10:17 am
I thought normal was used (sometimes) as better bump. I have models that have displacement and normal (rather than bump). Havent' set them up for octane though
gordonrobb
Previous
Return to Help / Tutorials
Tue Apr 16, 2024 11:25 pm [ UTC ]
