Octane denoising even when deactivated - 2020.2.1-R2
Forums: Octane denoising even when deactivated - 2020.2.1-R2
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby Kheewz » Wed Mar 17, 2021 11:41 pm
Kheewz Wed Mar 17, 2021 11:41 pm
My Octane C4D plugin is applying denoise on the beauty even when everything is deactivated, both on camera (in which I'm using Camera Imager) and on kernel settings. Also, there's no Overwrite Kernel Settings enabled.
If I'm rendering an exr multipass along the png beauty sequence, the former renders without denoising (including all passes), as should, while the latter is applying denoise.
Some images below:
This is how the render is coming out, even though it's set to 250 samples (PT) and the denoise is deactivated
This is how it should be, without denoise
These are my settings for this shot:
Kernel and active camera settings on denoise
I'm not new to Octane and I've made many projects enabling and disabling the denoise function. It's clear that there's something wrong, but I don't know what.
Also, I've tested this same scene on 2 completely different PCs, which I'm describing below:
PC 1:
Win 10
GTX 1080 ti
32gb ram
Studio Driver 461.92
Octane Plugin 2020.2-R3 and 2020.2.1-R2 (March 17th 2021 release)
Cinema 4D R23.008
PC 2:
Win 10
RTX 3090
32gb ram
Cinema 4D R23.110
Kheewz
Re: Octane denoising even when deactivated - 2020.2.1-R2
Postby aoktar » Thu Mar 18, 2021 10:31 am
aoktar Thu Mar 18, 2021 10:31 am
Could you please send your scene?
Postby Kheewz » Thu Mar 18, 2021 3:52 pm
Kheewz Thu Mar 18, 2021 3:52 pm
Hey, Ahmet!
Thanks for your fast response. I can't share this specific file, but while I was preparing a different scene to reproduce this case, I noticed something really strange.
The option "Use denoised beauty pass", which has always been present in the Main Octane tab, but had disappeared for sRGB in these versions that I prior mentioned, simply came back. That certainly solves the mystery.
Some images illustrating:
This is how the Main Octane tab is today, with the option to "Use denoised beauty pass" visible
This is how it was some days ago, without the "Use denoised beauty pass" visible while in sRGB mode
I've even found this Facebook thread while browsing for a solution some weeks ago.
Now I'm wondering, did you update anything on your end?
Kheewz
Postby lamloops » Thu Apr 29, 2021 12:32 pm
lamloops Thu Apr 29, 2021 12:32 pm
I'm having the same exact problem. Denoise is also screwing up all my materials in the newest version 2020.2.3, no density in specular mats, no reflections, emission problems, lights super blown out..
lamloops
Postby aoktar » Thu Apr 29, 2021 1:38 pm
aoktar Thu Apr 29, 2021 1:38 pm
lamloops wrote:I'm having the same exact problem. Denoise is also screwing up all my materials in the newest version 2020.2.3, no density in specular mats, no reflections, emission problems, lights super blown out..
Send what you have please!
Return to Bug Reports
Tue Apr 23, 2024 1:53 pm [ UTC ]
