Gradient map not visible
Forums: Gradient map not visible
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby oblivion » Fri Feb 07, 2020 12:31 pm
oblivion Fri Feb 07, 2020 12:31 pm
Hi there,
I create a composite material, put it on a plane.
Composite material consists of 2 materials controlled by a gradient. In the live viewer it shows fine, but when I render, I only see one layer.
You can see that very clear in the screenshot.
A bug maybe? Version is the latest stable 2019.1.5-R2
oblivion
Re: Gradient map not visible
Postby aoktar » Fri Feb 07, 2020 1:59 pm
aoktar Fri Feb 07, 2020 1:59 pm
what happen if you try this scene?
2.rar
(129.5 KiB) Downloaded 32 times
Postby oblivion » Fri Feb 07, 2020 3:14 pm
oblivion Fri Feb 07, 2020 3:14 pm
same thing
FYI: I am using win10, r21, 2x 2080 super rtx
oblivion
Postby aoktar » Fri Feb 07, 2020 4:04 pm
aoktar Fri Feb 07, 2020 4:04 pm
Seems like particular issue. What happens if you change cpu counts in settings/c4dshaders?
Postby oblivion » Fri Feb 07, 2020 5:40 pm
oblivion Fri Feb 07, 2020 5:40 pm
found the issue:
I had multi-thread for materials enabled. When disabled, everything works fine :-/ really would like to use this feature...
oblivion
Return to Bug Reports
Users browsing this forum: Bing [Bot] and 2 guests
Tue Dec 01, 2020 5:17 pm [ UTC ]
