Long Update Time
Forums: Long Update Time
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Long Update Time
Postby Brian_S » Thu Apr 26, 2018 2:42 pm
Brian_S Thu Apr 26, 2018 2:42 pm
A. Windows 10
B. 1080 Ti
C. 24 Gb
D. 397.31
E. 3.08
F. 3.08
G. C4D R19
H. Rendering project in Picture Viewer updateTM starts high and keeps climbing. Fluid is fully cached.
Would appreciate any help, thanks!
Brian_S
Re: Long Update Time
Postby Brian_S » Thu Apr 26, 2018 3:07 pm
Brian_S Thu Apr 26, 2018 3:07 pm
I'm at frame 26 now and the updateTM is at 63 seconds and climbing.
If more information is need let me know.
-Thanks
Brian_S
Postby aoktar » Thu Apr 26, 2018 8:19 pm
aoktar Thu Apr 26, 2018 8:19 pm
You're posting expected behaviour with high polygon counts as a bug. You should note that update time is increasing in log outputs. If you think it's longer than as in Live Viewer so you should read this: https://docs.otoy.com/Cinema4DH/C4DPlug ... Tricks.htm
Postby Brian_S » Thu Apr 26, 2018 8:51 pm
Brian_S Thu Apr 26, 2018 8:51 pm
Sorry about that... I thought it was a bug. I didn't think this was normal behavior taking this long to update the PV when working with 4 mil triangles.... which increase as the mesh gets more complicated.
I read the page you linked to.
Pardon my ignorance, but is the time it's taking to update the scene seem normal to you? ...or is it getting bottle necked somewhere? Maybe I could optimize my scene somehow?
I truly appreciate your help.
Brian_S
Postby Brian_S » Thu Apr 26, 2018 8:55 pm
Brian_S Thu Apr 26, 2018 8:55 pm
I'm sorry I see you referred to it as expected behavior... so these times are normal for the poly count.
- Thanks
Brian_S
Postby aoktar » Thu Apr 26, 2018 10:07 pm
aoktar Thu Apr 26, 2018 10:07 pm
Yes! Incoming V4 is much faster on this cases.
Postby pacey84_1 » Mon Feb 15, 2021 11:56 am
pacey84_1 Mon Feb 15, 2021 11:56 am
Hi the link to the manual is broken. Could you kindly update where it is supposed to go to please.
I am getting very long update times relative to the live viewer, and it is reloading every frame, when there are only static geometry with moving camera and lights.
I'm sure there are a few boxes I can tick to speed this up?
Log for a typical frame, note the 'updateTM':
FRAME:1453 fps:25
createTM=0.043sec. 42.554
MB:0/0 ST/MOV:0/1 Nodes:24 Tris:13.85m DispTris:0 Hairs:78k Meshes:4
Textures Grey8/16:0/0 Rgb32/64:0/0
VRAM used/free/max:3.612Gb/4.65Gb/11Gb Out-of-core used:0Kb RAM used:25.802Gb total:47.901Gb OpenGL free/total:0/0
mblurTM=1.379sec. createTM=0.043sec. updateTM=18.478sec. renderTM:1.129sec. totalTM:19.672sec.
Tonemapping the all passes tm:60.134
stored passes in:21.241 cores=12
Displaying passes in tm=11.854
Passes saved in:0.123sec.
pacey84_1
Postby bepeg4d » Tue Feb 16, 2021 7:08 am
bepeg4d Tue Feb 16, 2021 7:08 am
what happen if you disable Motion Blur?
Moving lights are like moving objects, only moving Camera has a special treatment for fast Motion Blur.
ciao Beppe
Return to Bug Reports
Who is online
Users browsing this forum: No registered users and 2 guests
Thu Apr 25, 2024 1:20 am [ UTC ]
