[SOLVED] Rotating HDR doesn't update Live Viewer
Forums: [SOLVED] Rotating HDR doesn't update Live Viewer
Sub forum for bug reports
Moderator: aoktar
C. RAM Capacity (i.e. 6 GB)
Postby Hurricane046 » Thu Dec 08, 2022 10:31 am
Hurricane046 Thu Dec 08, 2022 10:31 am
RotX and RotY doesn't update the Live Viewer, making it impossible to work the lighting conditions. Power slider works.
Scene file: https://mab.to/t/c0sxOn2IY58
Cinema 4D 2023.1 + Octane 2022.1
Solved by using ImageTexture node in the Environment Tag.
I was used to skipping it, but now it's a requirement for the Rotations to update the Live Viewer.
2x RTX 2080 Ti | 2x RTX 2070 | 2x GTX 1080 Ti | 1x GTX 1080 | 1x GTX980 Ti
Hurricane046
Re: [SOLVED] Rotating HDR doesn't update Live Viewer
Postby aoktar » Thu Dec 08, 2022 12:50 pm
aoktar Thu Dec 08, 2022 12:50 pm
How can you change the Gamma if you use C4D's Bitmap else of ImageTexture for example?
Postby Hurricane046 » Fri Dec 09, 2022 8:34 am
Hurricane046 Fri Dec 09, 2022 8:34 am
You mean this? Power slider working, while RotX, RotY doesn't when I'm not using the ImageTexture node?
Hurricane046
Postby bepeg4d » Fri Dec 09, 2022 8:59 am
bepeg4d Fri Dec 09, 2022 8:59 am
please, always use an ImageTexture node before loading any kind of image into c4doctane:
https://docs.otoy.com/cinema4d/ImageTexture.html
Octane is a Spectral render engine, so every texture must to be converted to the proper color space before been used.
This is even more important for Lighting, and in particular for the Environment node.
Please press the light blue icon to automatically create the ImageTexture node:
Then load inside it the desired HDRI. In this way you will be able to change the Gamma, that should be set to 1 for all 32bit image textures, and use the RotX/Y sliders.
ciao,
Beppe
Return to Bug Reports
Thu Apr 25, 2024 12:14 am [ UTC ]
