Page 3 of 11
Re: Cinema4D version 2022.1-XB1-(R2) (Experimental) 26.05.2022
PostPosted: Thu May 26, 2022 6:48 pm
by aoktar
PostPosted: Thu May 26, 2022 11:10 pm
by Meet
Thank you, color VDBs work great!
Thin film in standard surface material still doesn't work
PostPosted: Fri May 27, 2022 12:38 pm
by aoktar
Have you checked in Standalone? It's not working in there too.
PostPosted: Fri May 27, 2022 1:39 pm
by Meet
aoktar wrote:Have you checked in Standalone? It's not working in there too.
Yes, I had checked and asked, it works in standalone
Metalness is 1
PostPosted: Fri May 27, 2022 2:11 pm
by aoktar
Metalness is 1
It's working if you connect a float texture. Assumed that's not working because used rgb color.
PostPosted: Fri May 27, 2022 9:33 pm
by SSmolak
Undo doesn't work if node is still selected after changing parameter while using embedded GUI
PostPosted: Sat May 28, 2022 1:25 am
by jiabangshou104
"Photon Tracing "often gives memory RAM errors when noise reduction is enabled.
Octane Render AOV group cannot be saved.
"Photon tracing"在开启降噪时经常出现内存RAM报错。
使用Octane Render AOV group时无法保存。
PostPosted: Sat May 28, 2022 2:24 pm
by SSmolak
Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
PostPosted: Sat May 28, 2022 7:56 pm
by aoktar
SSmolak wrote:Changing Layered Material type to different one like Diffuse doesn't work. Only way is to create new material from scratch.
The attachment layered.jpg is no longer available
Not sure what are you showing and how you can see this menu command. It's not appearing on sub materials. And deleting/creating is not only way to change the type. See pic.
PostPosted: Sat May 28, 2022 7:59 pm
by SSmolak
I mean Octane Composite. I thought that this menu is to convert it to something else ( not layered one ). I have old material with which is layered that now can be done using Octane UIniversal but I see that there is no way to simple convert or change it to Universal one.
