Cinema4D version 2020.1.3-R2 (Obsolete stable) 24.06.2020
Forums: Cinema4D version 2020.1.3-R2 (Obsolete stable) 24.06.2020
Moderator: aoktar
Re: Cinema4D version 2020.1.3-R2 (Latest stable)24.06.2020
Postby AaronWestwood » Tue Jul 21, 2020 1:40 am
AaronWestwood Tue Jul 21, 2020 1:40 am
stuz0r wrote:I was just curious if anyone else has been having the color space issue? I can't seem to get it to work properly yet. It's like it's forcing the EXR file type into linear workspace when working in post.
Is there any update to this? EXR's are currently broken with the color space as Stuart mentioned, reverting to linear regardless of settings on render. The previous version didnt have this issue :)
I updated to this version for the denoiser fix, but unfortunately still cant render due to this exr bug.
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
AaronWestwood
Postby bepeg4d » Tue Jul 21, 2020 8:35 am
bepeg4d Tue Jul 21, 2020 8:35 am
foureyez wrote:hi Beppe,
Enclosed the screenshot of the console window.
https://ibb.co/RP8GQz3
Hi, it seems that you have shared the Python log... please, open a scene, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
ciao Beppe
Postby KonstantinosD » Tue Jul 21, 2020 11:48 am
KonstantinosD Tue Jul 21, 2020 11:48 am
Hello Ahmet,
Thanks for the updates!
Could you please check that the ground color and ground start angle work as intended in the latest version? They dont work in mine. Octane model has no ground, and in the other models the color works, but not the start angle.
Thanx for your work.
Konstantinos.
2X Win10 PRO, Asus ROG Zenith Extreme Alpha, AMD 2990WX , 64GB ram, 2X 2080ti, all watercooled, custom loop.
KonstantinosD
Postby aoktar » Tue Jul 21, 2020 12:29 pm
aoktar Tue Jul 21, 2020 12:29 pm
Actually fixed it but waiting for a better sdk with less issues.
Postby james_conkle » Wed Jul 22, 2020 12:31 pm
james_conkle Wed Jul 22, 2020 12:31 pm
I'm planning on doing a fresh windows install soon after I get my ECC ram(going for maximum stability this time)... Would this be a good version to use with R21 as far as stability goes? And any recommendation as to what Nvidia driver / Windows version to use?
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
james_conkle
Postby nejck » Wed Jul 22, 2020 1:23 pm
nejck Wed Jul 22, 2020 1:23 pm
james_conkle wrote:I'm planning on doing a fresh windows install soon after I get my ECC ram(going for maximum stability this time)... Would this be a good version to use with R21 as far as stability goes? And any recommendation as to what Nvidia driver / Windows version to use?
Not sure if this is going to be helpful but I find it pretty random as to what combination of things will work. I have a Xeon build with ECC RAM and some versions just crash more often than others. Same goes for drivers. Personally, once I find a version that just works (R6 it is right now and 442.92 driver version) I just stick to it. Once the really useful version updates come through then that is the time I start experimenting.
I don't want this to come off as too negative as I like the software and I'm sure the team is rocking it but I do want to be honest. I do think that things are getting more stable lately so thats also important to note. :)
nejck
Postby james_conkle » Wed Jul 22, 2020 5:12 pm
james_conkle Wed Jul 22, 2020 5:12 pm
nejck- That's good to know, thank you! I'm new to the whole 3D world so it's a bit different with the software cycles, but your system sounds good to me. I'll start with the current release since it was stable on R21 of c4d and just install S22 for uv unwrapping lol
I noticed the Nvidia 442.92 driver is from April so that doesn't have the new Windows GPU scheduling feature, but since that's a big change I too would be cautious about it. I'm also planning on upgrading to Windows Pro on my fresh install so I can remove the automatic updates... Just deciding if I should find an older version before the GPU scheduling change (I guess I could keep it turned off too...). Sorry for the non-plugin related talk :(
james_conkle
Postby AaronWestwood » Wed Jul 22, 2020 7:41 pm
AaronWestwood Wed Jul 22, 2020 7:41 pm
Thanks for the reply Aoktar :) I know its always tricky to estimate these sorts of questions, but is there a rough release date for that? Just planning renders...
AaronWestwood
Re: Cinema4D version 2020.1.3-R2 (Obsolete stable) 24.06.2020
Postby Antoncromas » Mon Aug 31, 2020 2:23 pm
Antoncromas Mon Aug 31, 2020 2:23 pm
nVidia 451.67 works great for me. Latest driver isnt stable on my machine.
Antoncromas
Previous
Return to Releases
Users browsing this forum: No registered users and 11 guests
Thu Apr 25, 2024 11:47 am [ UTC ]
