Cinema4D version 2020.1.2 (Obsolete)11.06.2020
Forums: Cinema4D version 2020.1.2 (Obsolete)11.06.2020
Moderator: aoktar
Re: Cinema4D version 2020.1.2 (Latest stable)11.06.2020
Postby aoktar » Fri Jun 19, 2020 10:51 am
aoktar Fri Jun 19, 2020 10:51 am
Sorry about your criticisms. We should label it STABLE if you/all accept that previous builds are STABLE. Because they were having more CORE bugs and fixed in this CORE. And the plugin is adjusted to provide lighter workflow while working on the content.
Now the latest CORE has a problem with VDB loading. That doesn't mean it's not STABLE, but have a problem. Of course, I'm not happy to see some shadowing on our heavy efforts. I believe you're very kind to accept temporal mistakes and wait until we fix it very soon. And you'll have a better product.
Postby fatrobotsneedlove » Fri Jun 19, 2020 7:16 pm
fatrobotsneedlove Fri Jun 19, 2020 7:16 pm
aoktar wrote:Sorry about your criticisms. We should label it STABLE if you/all accept that previous builds are STABLE. Because they were having more CORE bugs and fixed in this CORE. And the plugin is adjusted to provide lighter workflow while working on the content.
I know it wasn't your fault ahmet. I get core vs plugin.
I rolled back to 2020v4 two days ago, and it got killed today. Just got an error that says its not supported anymore.
Very frustrating that I can't use the current version because VDBs are broken, and the last version that worked for me (2020 v4), which I kept on my computer as a backup, does't work either.
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
fatrobotsneedlove
Postby aoktar » Fri Jun 19, 2020 7:20 pm
aoktar Fri Jun 19, 2020 7:20 pm
We're not happy too but there are humans that work on, I believe that you can do mistakes also! Isn't?
You should use this version(R7) until next build, R4 is not fine!
viewtopic.php?f=85&t=74603
Postby fatrobotsneedlove » Fri Jun 19, 2020 7:24 pm
fatrobotsneedlove Fri Jun 19, 2020 7:24 pm
I really wasn't trying to disrespect anyone. I truly apologize if it came across that way.
I will try to phrase things differently in the future.
But please understand that when things break and don't work, WE get yelled at. WE lose clients.
I got yelled at today.
fatrobotsneedlove
Postby aoktar » Fri Jun 19, 2020 7:30 pm
aoktar Fri Jun 19, 2020 7:30 pm
fatrobotsneedlove wrote:I really wasn't trying to disrespect anyone. I truly apologize if it came across that way.
I totally understand the pressure you have. But why don't you download 2020.1-R7 from the link I sent?
It's very stable one
Postby Goldorak » Fri Jun 19, 2020 7:48 pm
Goldorak Fri Jun 19, 2020 7:48 pm
This is on our end, and this is being addressed ASAP in 2020.1.3 hotfix. I’m so sorry this slipped through the Q&A for .2, it’s related to an openVDB library update made in 2020.1.1.
Goldorak
Previous
Return to Releases
Users browsing this forum: No registered users and 11 guests
Tue Apr 23, 2024 4:48 pm [ UTC ]
