Cinema4D version 2020.1-RC4 (ReleaseCandidate) 21.04.2020
Forums: Cinema4D version 2020.1-RC4 (ReleaseCandidate) 21.04.2020
Moderator: aoktar
Re: Cinema4D version 2020.1-RC4 (ReleaseCandidate) 21.04.2020
Postby aoktar » Wed Apr 22, 2020 1:16 am
aoktar Wed Apr 22, 2020 1:16 am
zoppo wrote:
aoktar wrote:Did you make all tests for every cases? You don't know back processes about the renderer and plugin for image storage and processing, even I don't know the renderer side. So I can't claim that's a bug or problem.
I didn't, I don't, and why should I?
On the other hand I did show you pictures in the 2019-thread: Pick a texture > put it in an "image texture" node > look at the Octane Texture Mangager's Vram column.
Now change the (RGB) texture's type to float and, according to the Octane Texture Manager, nothing changes regarding the Vram.
"Works" in v2019 and v2020.
So either the "Float" setting has no effect, or the Texture Manager ignores it. I would call that a bug, even without knowing "back processes about the renderer and plugin for image storage and processing". If it's not the plugin not processing the setting, but the underlying Standalone, just pass it on to the Standalone guys, please.
@kalua - That's where ;)
If you relly to texture manager for this, do not that. It cannot know exact vram usage. Just using a rough formula, the renderer handles everything and plugin cannot know details. I think you didn't watch the video and render info for vram usage. For your request, it doesn't make any sense.
Postby zoppo » Wed Apr 22, 2020 9:07 am
zoppo Wed Apr 22, 2020 9:07 am
aoktar wrote:If you relly to texture manager for this, do not that. It cannot know exact vram usage. Just using a rough formula, the renderer handles everything and plugin cannot know details. I think you didn't watch the video and render info for vram usage. For your request, it doesn't make any sense.
Yes, I did not see the video because I was on my mobile. So it's just the Octane Texture Manager that is not showing the correct values, good to know.
Although it is strange because this does work in 4.05 - I just tested it.
C4D 2023 | Win10
zoppo
Postby aoktar » Wed Apr 22, 2020 9:51 am
aoktar Wed Apr 22, 2020 9:51 am
Renderer's internal functionality changed. It's much more complex now. We can't know the real vram usages because of it. At least I don't know ATM.
Postby colektor » Wed Apr 22, 2020 4:44 pm
colektor Wed Apr 22, 2020 4:44 pm
Work's really fine
The Motion blur + Xparticles work very good
Thanks lot !
colektor
Postby aoktar » Wed Apr 22, 2020 7:07 pm
aoktar Wed Apr 22, 2020 7:07 pm
colektor wrote:Work's really fine
Thanks lot !
Thanks for feedback! Let me know any issues
Postby Kalua » Wed Apr 22, 2020 8:15 pm
Kalua Wed Apr 22, 2020 8:15 pm
I have been playing with float and normal type with image textures, and althought the texture manager doesn't report changes, the live viewer will apparently give you some more accurate readings: the values floctuates as soon as you start playing with normal/float types.
C4D 25.117 Octane 2022.1.2 R4, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 536.67
Kalua
Postby nejck » Thu Apr 23, 2020 9:05 am
nejck Thu Apr 23, 2020 9:05 am
If you guys want to quickly test if its working just plug in an 8k map in there and switch between normal and float. The difference should be noticeable :)
nejck
Postby oblivion » Thu Apr 23, 2020 1:00 pm
oblivion Thu Apr 23, 2020 1:00 pm
excellent release, I think
I am only working on lighter scenes right now, but no crashes so far, even with RTX turned on. And its BLAZING fast... :-)
I think this was mentioned somewhere before, but is there a difference between "Random walk" and "Randomwalk"? :D
oblivion
Postby paypal-ict » Mon May 11, 2020 9:57 am
paypal-ict Mon May 11, 2020 9:57 am
Will OpenColorIO be suported in the next version? Or will RC4 become the new Stable version?
paypal-ict
Previous
Return to Releases
Users browsing this forum: No registered users and 11 guests
Thu Apr 25, 2024 1:34 pm [ UTC ]
