aoktar wrote:Mysterium wrote:Hi !
I have a material - universal - with "Image Tiles" nodes plugged into some channels. Each time a project is closed and then opened, the Image Tiles stop working and I have to create new ones and all re-setup these new Image Tiles nodes so that they work again.
OK, would you mind to share example project to show it? Also did you try on different scene with a different setup?
I tested on different machines, and in multiple scenes and it's the same problem.
EDIT 1: Rather than recreating the nodes, I can also fix the problem by cutting and pasting the names of the textures in the files field of the ImageTiles.
I have to do it with the live viewer on before re-rendering each scene otherwise it is not taken in the final rendering.
