aoktar wrote:Try with driver 417.22.
Sorry, im a dumbass and cant read instructions. I only had to remove .cdl64 files for other C4D versions from the plugin folder and it fixed the freeze (so far works on 417.71 drivers too).
Moderator: aoktar
Silverwing wrote:Hi there Ahmet.
I encountered a problem when opening old scene files that have been saved with Octane 3.07 or earlier.
The BSDF Flag, that should be set to "Octane" for compatibility reasons is not set at all in the materials, causing them to look different in the renders and therefore are not consistent anymore with the renders made with the older scenes.
I recorded a small video to showcase the problem
Download the Material Scene to investigate:
Material Scene
Raphael
VVG wrote:Render region and film region workf fine?
1. Both modes consider a limited number of samples that are specified in the settings.
2. do not show the total number of samples
3. sometimes work fine
R19
GiWest wrote:aoktar wrote:Try with driver 417.22.
aoktar wrote:VVG wrote:Render region and film region workf fine?
R19
Yes all fine! Nothing changed there since a few versions. Maxsamples goes until 1000000 without stopping in region mode. Film region will stop at Maxsamples.
aoktar wrote:Silverwing wrote:Hi there Ahmet.
Material Scene
Raphael
It should be fixed on 4.02.1-R2. Are you seeing that in this version?
Users browsing this forum: pcoombes and 6 guests
