Version 3.08.1-R4 (obsolete stable)
Forums: Version 3.08.1-R4 (obsolete stable)
Moderator: aoktar
Re: Version 3.08.1-R3 (latest stable)
Postby siha » Tue Jul 03, 2018 9:02 pm
siha Tue Jul 03, 2018 9:02 pm
not sure if this is a bug, but I found out, that OSL-Texture only compile when the material is applied to an object? Is this wanted?
siha
Re: Version 3.08.1-R4 (latest stable
Postby cmittenaere » Thu Jul 05, 2018 11:50 am
cmittenaere Thu Jul 05, 2018 11:50 am
Thank you,
but I think it doesn't work with network render...
cmittenaere
Postby bepeg4d » Thu Jul 05, 2018 1:35 pm
bepeg4d Thu Jul 05, 2018 1:35 pm
cmittenaere wrote:Thank you,
Hi Network rendering is working correctly with 3.08.1-R4, you need to install 3.08.1 daemon on the Slaves:
viewtopic.php?f=24&t=67352
ciao Beppe
Postby eyeonestudio » Sat Jul 07, 2018 2:36 pm
eyeonestudio Sat Jul 07, 2018 2:36 pm
Currently the Forester - Multi Cloner works well.
However, Display Points must be Off.
If you turn off Display Points, the viewport will be very slow.
This is got a lagging.
If you can get information from the Forester developer
Can render with Display Points on? (Like Scatter Object) :)
CINEMA 4D R2023
Win10 / 10GbE / AMD3995X*2ea, AMD3990X*2ea, 10980XE*2ea / 256Gb RAM / RTX3090*14ea
eyeonestudio
Previous
Return to Releases
Tue Apr 16, 2024 9:37 am [ UTC ]
